REVIEW INCL. Just got monoprice speaker wire in.....why do you guys reccomend this so much?
32K views 371 replies 56 participants last post by  CharlesJ
#1 ·
so I posted a thread about building a cheap system here:
http://www.avsforum.com/t/1519352/threw-together-this-cheapo-system-what-do-you-guys-think
upon heavy recommendation from the forum, and nearly half of the forum viewing that monoprice is the best audio cable on the market for the best price.
http://www.avsforum.com/t/1518761/whats-your-favorite-cable-manufacturer-poll
with that said, I took the plunge and ordered some of it. and I went to radio shack to buy AUVIO to decided what I wanted to run.
first impressions of mono-price cable. along with a comparison to what is available to me locally.
1: dirty, when I opened the box, the spool looked used, beaten to hell and wrapped in what looked to be used/recycled sandwhich wrap.
it's not a big deal, so I took the cable off of the melting card board spool and discarded it. smelled like cheap china product you get on ebay, which nobody tells newbies for some reason.
I ordered 50 feet no logo, I got 50 feet no logo so that's a plus. radioshack's 25 foot spool only had about 20 feet in it.
2: it's thinner, and the strands are wrapped in a sloppier manner than the AUVIO cable. Radioshacks cable looks good, looks expensive, looks quality like what you would expect a "high end" speaker system to use.  Mono-price stuff SHOULD BE SLEEVED/COVERED/BOOTED in my opinion
3: it's closer to radio-shack's 14 gauge cable than the 12 gauge, monoprice claims that the jacketing is thicker on the radioshack stuff hence the thickness difference, not true, I striped the jacketing off to get a banana plug on it, and there is more copper on the radio shack AUVIO 12 gauge.
jacketing quality is poor, takes 1-4 strands when you strip it no matter how great your stripper is. auvio cable is easier to strip, strips kind of like Monster cable i had in my boat/car 10 years ago, or like the great speaker cable that pioneer gave us on my dad's 90's 5.1 DD theater system.
the fittings from monoprice are harder to use than the banana plugs I picked up at radio-shack as well (however there is a $15 price difference PER SET, so pick your poison there, I just dealt with the so-so plugs at the speakers and sub, but I sprung for the higher end plugs at the amp end due to it being the expensive part of the system)
ending notes: I would NOT recommend this cable for someone who will have speakers in a visible location. but If it is used in a manner where you can see very little of it, or if you plan on sleeving it, it works fine.
monoprice 12 gauge cable is low end, cheap cable made thicker, if you take anything from this review, buyer beware, this brand is hyped because ......i don't know................it looks nearly identical to the low end RCA brand speaker wire sold at Walmart, just about 3 times as thick.
See less See more
4
#2 ·
How does cardboard melt?
Do you really think radio shack manufactures cable in the US?
It's wire, it doesn't matter.
Why? Does that make it sound better?
This has nothing to do with cable and very much to do with your skill in using tools.
Again, your skills appear to be lacking.
Makes very little sense, perhaps you don't know what wire gauge means.
i don't know
#3 ·
Originally Posted by SAM64  /t/1520500/review-incl-just-got-mon...you-guys-reccomend-this-so-much#post_24427298
the way that the cardboard is in the pic is how it was delivered to me, looks like it was exposed to water or damaged at somepoint.  I highly doubt that Norco overnite, overnight service damaged it that badly in transit.
china made goods, still have variable quality differences, radioshack's cable is clearly a higher end cable
it's a car it doesn't matter, it's just a house quality doesn't matter !!!!
more visually appealing,  and it doesn't lay as nicely as radio shack's cable. I spent good money on a fractal design define case, why would I lay a bunch of cheap cable next to it?
alluding to the fact that it's not as advertised. I guess you don't know what a Ferrari is? I slapped a Ferrari badge on my camry therefore it's a Ferrari and anyone who says otherwise is an idiot
#4 ·
Including the words best and monoprice in a sentence is almost sure to result in an oxymoron. Monoprice is nothing more than a reliable supplier of commodity products at hard to beat prices. You are comparing $.30/ft cable from monoprice to $1.00/ft cable from Radio Shack. For the difference in price you get a plastic reel instead of a paper one, which is meaningless once you install the cable. You also get rope lay cable that looks better and larger than the monoprice cable, and strips a little easier. But they are both 12 AWG and you won't hear a difference. Most folks aren't very concerned with the look of the cable because it is out of sight and who bothers to look at speaker cable anyway. If looks are important, it may be a good idea to use something other than the cheapest cable.
#6 ·
Good review. Thanks for posting it. I do fair amount of bargain shopping at Harbor Freight for tools. While there are a number of tools that are good enough, the nasty stuff is nasty. Yes, they can do the job. But boy, you pick them up and they feel terrible. Such was the case with a set of screwdrivers. The handles looked ergonomic and fancy in the picture. But the moment you picked them up, you wanted to put them back down. It was anything but ergonomic and the feel was just awful.
How well something feels is of value. You don't want to feel disgusted as soon as you open the box. Folks should report the things you mention in their recommendations just in case it matters to some.
It would be interesting to measure the resistance of the monoprice cable to see if it is indeed 12 gauge. So much Chinese stuff is mis-marked as being better than it is.
#7 ·
Originally Posted by amirm  /t/1520500/review-incl-just-got-mon...you-guys-reccomend-this-so-much#post_24428640
Please do that and report back with your findings.
  • Like
Reactions: sivadselim
#9 ·
No need for me to invest in both cables for you to test and prove a point. But! Ask the OP to send samples to you so you can perform the testing and provide the comparison.
What speaker wire does your business use?
In all reality, based on the OP's thread about building a "cheap system", I don't understand why the "quality or lack of quality" of a speaker wire should be so important.
#10 ·
Originally Posted by Ratman  /t/1520500/review-incl-just-got-mon...you-guys-reccomend-this-so-much#post_24429736
Well, sounds like you weren't interested in the answer that much after all! Let me know if your curiosity ever rises above that. As for OP sending it, he bought a very short length of it. While I can use a 4-wire Kelvin measurement system, preferably I like to have much longer lengths to measure its resistance properly. 100 foot would be nice.
Not monoprice
. Not only do we care how good the wires is now, we also care how good it is down the road. I have cheap crappy speaker wire from years ago and some are totally disgusting with green leads, sticky insulation, etc.
That's fine. He doesn't expect everyone to get it....
#11 ·
While I agree this is cheap stuff, the fact that you lose a few strands on a 12awg wire means nothing performance wise. Some people think that if any strands are lost, the wire is no longer the same gauge. This is not exactly correct. It's all about resistance. The loss of a few strands for the half inch going into a connector is highly insignificant. Probably far less increased resistance than the connector it's self adds.
P.S. I am talking about communications cable here with high strand count. Obviously losing strands on electrical power wire with lower strand count is a different matter.
#12 ·
I have a roll of the Monoprice AWG 12 speaker wire, as well as a roll of AWG 12 wire of the "Sound King" brand that I got from Parts Express. I compared them, and sure enough, the Sound King wire looked quite a bit thicker. So I looked at them both under a magnifying lamp, and the result is just as Colm says. It is the "rope lay" that makes the Sound King wire look bigger. For readers not familiar with rope lay, there are multiple, smaller groups of stranded wire bundled within the insulation. It looks like six smaller stranded wire groups: five around the outside and one in the middle. The insulation of the Sound King wire is thicker too.
#13 ·
Originally Posted by amirm  /t/1520500/review-incl-just-got-mon...you-guys-reccomend-this-so-much#post_24429830
But you do.
What speaker wire does your business use? You never answered.
And when I test wire, " I have a dual-column gas chromatograph, Hewlett-Packard model 5710a with flame analyzing detectors."
#14 ·
Originally Posted by Ratman  /t/1520500/review-incl-just-got-mon...you-guys-reccomend-this-so-much#post_24430158
But you do.
Of course. I appreciate well engineered and manufactured products. I know what shortcuts can be taken and like it when that is not done. I examine anything I buy and when there is an effort above and beyond, I appreciate it. Ask anyone who buys Apple products what they think of their packaging. Surely you don't take the iPhone packaging with you and it does nothing for the phone (other than safe keeping) but it is part of the draw of Apple products. We call that OOBE: out of box experience.
It is not the topic of the thread.
Good to hear you at least have good taste in movies
#17 ·
Originally Posted by amirm  /t/1520500/review-incl-just-got-mon...you-guys-reccomend-this-so-much#post_24430254
Well, perhaps it is.
You stated you don't use Monoprice speaker wire (with wink and a smile).
You also stated, "Not only do we care how good the wires is now, we also care how good it is down the road. I have cheap crappy speaker wire from years ago and some are totally disgusting with green leads, sticky insulation, etc."
So? What product (speaker wire) do you promote, sell, install etc. to your customer(s)?
I think that's a fair question.
(Did you take dance lessons from Fred Astaire or Gene Kelly?)
#19 ·
Originally Posted by Ratman  /t/1520500/review-incl-just-got-mon...you-guys-reccomend-this-so-much#post_24430513
I said your question is off-topic. The topic is monoprice quality. I said we don't use it. And gave reasons.
BTW, I took a look at the Monoprice 12 gauge speaker wire spec. This is what it says:
"Resistance per Meter: 0.0072 ohm
Cross Sectional Area: 3.0mm Sq."
If we look up the wire guage nominal specs, we get this for 12 gauge:
Resistance per meter = 5.211 milliohm/meter or .0052 ohm = 1.588 milliohm/foot
Cross sectional Area = 3.31 mm squared
Let's cross check our reference with Belden 12 gauge speaker wire:
Nom. Conductor DC Resistance: 1.56 milliohm/foot
The Belden matches our reference almost to the digit when it comes to DC resistance: 1.56 vs 1.588. So our reference and real products essentially match which is good.
The monoprice on the other hand has a DC resistance per meter of .0072 instead of .0052. This means its resistance is 39% higher per meter than Belden/reference for 12 gauge. By my interpolation the monoprice DC resistance is somewhere between 13 and 14 gauge wire!
We can see the reason why. The cross section area of the monoprice conductor is 3.0 mm instead of 3.31. Thinner wire --> higher resistance. Thinner wire --> cheaper cost.
Someone should double check my quick math above and unless I made a mistake, you sure are getting something else than what it says.
Anyone who has dealt with chinese products in electronics knows about such exaggerations and then some. Never trust the stuff without testing and performing some due diligence.
Let's be professional please and stay on the technical topic.
#20 ·
Originally Posted by FMW  /t/1520500/review-incl-just-got-mon...you-guys-reccomend-this-so-much#post_24430289
Nobody said Monoprice was the best. What we say is that it is inexpensive and will do the job of any other wire. Nothing incorrect about that.
Is there any test results that states so? I.e. that it does the job of any other wire?
#21 ·
Originally Posted by amirm  /t/1520500/review-incl-just-got-mon...you-guys-reccomend-this-so-much#post_24430707
I said your question is off-topic. The topic is monoprice quality. I said we don't use it. And gave reasons..
No it's not. Fine, you don't use it. What do you use?
You're a professional... what do you suggest and/or use for your clients?
#22 ·
There's always a way to spin this your way right? Why not check the Monoprice CL-2 speaker wire as comparison to the Belden CL-3 wire you're referencing?
Monoprice CL-2 has DC resistance at .00543 ohm/meter. Belden specs .00511 ohm/meter. Well, that's a little closer now isn't it? Spread your wings a bit
Monoprice
#23 ·
Originally Posted by fotto  /t/1520500/review-incl-just-got-mon...you-guys-reccomend-this-so-much#post_24431135
Monoprice
I did not compare them to Belden. I used the Belden spec to verify the nominal values that are listed in Wiki page on wire gauge. I then used the table to show that their stated 12 gauge does not comply with industry standards.
As to CL2 cable you list, that is not what OP bought. That's an in-wall cable and not the topic of this thread. Did you not notice that from the jacket of the cables in OP's pictures? Here is the CL-2:
Doesn't look like OP's cable, now does it? And who says their specs are right anyway? I trust Belden's because many people have put them to test. But these guys? Do you have some real measurements you can share?
This is what proper cable specs looks like: http://www.canare.com/ProductItemDisplay.aspx?productItemID=65
Example:
Is there anything resembling that in their CL2 specs? I think not. Over long distances where in-wall cables are used, you need a lot more than a couple of numbers.
Back to the original cable from OP, in your book it is OK to mark a speaker cable as 12 gauge but have it be nearly 14 gauge? Just because there is *another* cable that is ostensibly 12 gauge? I hope not.
Why defend such a conduct? To what end? Why are you guys not pro-consumer in such matters? We are supposed to be sold less goods than what the label says???
Is there some undercurrent here that I don't understand that leads to such posts?
#24 ·
you guys can call me an idiot, or stupid/unskilled all you want and defend the brand thatgives your admin a kickback + payperclick ad sales
however, i think the pictures showing the comparison ofthe wire speaks for it's self.
monoprice thrives on your abilities to dance around topics, and defend it to no end. but there is 50 feet of it...sitting next to a better product.....you can ignore it, youcan claim oh that's just rope laidcopper and a thicker jacket that is easier to use, widely available, and sold with a warranty.
what else are you guys going to say? that fork marked stainless steel is just food grade stainless steel, for $1 less you can get one marked stainless steel and is actually made from  LEAD, it does the job, only thing is it might kill ya,
not like those features make for a better product of anything...greed motivated
#26 ·
Originally Posted by lynchking  /t/1520500/review-incl-just-got-mon...you-guys-reccomend-this-so-much#post_24431734
For Pete's sake, we're talking about a cheap spool of wire. Return it or throw it out or vow never to buy anything from the site again. But this is truly ridiculous.
