OK been a few years since i last built a PC never built HTPC.
But decided on the Moneual 312 (Only one the wife liked the look of)but thats about it the rest is up in the air. looking to spend upto £1000 on the front end machine.
Aim is to have a near silent good looking front end machine hence the 312 that i can play all my media from. This i intend to put on a gigabit ethernet network where i will store all my media (3x2TB Seagate Pipeline or better if you have suggestions).
Requirements Are HD Video and 7.1 sound, BluRay, DVD, CD, Home Movies playback.
Current thoughts:
8GB DDR3 1600Mhz Corsair RAM (is this good enough)
MOBO Asus P8P67-M Rev3.0 Intel LGA1155 Sandybridge (are there better boards for this sort of application)
GPU Nvidia GT430 2GB Low Profile(or is there a better GPU option)
CPU Intel i5 2500k Sandybridge (or should i go with i3 as most people on here seem to use it is there a reason)
PicoPSU 160w (Will this be OK)
BD-Rom ??(Open to suggestions)
Fans ?? very quiet ones.(What is considerd best method need advice on this)
Not sure whether to only use a 64GB SSD in the front end or will i need HDD in there aswell is i want to store my media an a different machine any advice if any one has gone done this route gratefully accepted.
Have tried to troll through most of this thread and i think i ended as unsure by the end only thing i really decided on was the PicoPSU but i bet someone now turns round and says that isnt a good option...LOL. hope not
Any help or advice on this would be much apprieciated
Current thoughts:
