I had a PTAE3000U and it is out-of-order for a moment while I get the fans replaced. It could take a long time and it might not even fix the issue. I can't really explain without going into a huge story about why, but I have a $1000 owed to me that I have to spend before it is no longer available. What I want to do is just buy a projector that is equal or better in picture quality to the 3000U. Now I know the features won't be the same, but I never really used the features anyways except for the frame creation and i'm told that I'm not going to find that in anything but a Panny. I would like 120hz though.
I refuse to believe that a 2k projector in 2008 won't have something equal in picture quality at 1k price point 6 years later.
my stats-
What are your viewing habits? Blu-Ray, Streaming from a PC and an Xbox/PS4
What is your room like? It's a little den area with complete light control.
What are your room dimensions? 13x11 with the height being about 9-10 feet
What are your room colors? beige with white ceiling
What is your throw distance (lens to screen distance)? My throw distance is 12' [could be moved to around 10' if absolutely necessary] and the screen is 92''. The projector shelf is at the base level of the screen, but shelves can be moved and screen can be moved up or down. I can't ceiling mount since i live in an apartment and I don't want to put it in the middle of the room on a table.
What is your viewing distance - 10'
What are your quality expectations? I just want it to look as good, hopefully better than my other projector.
As far as screen size and throw distance... I just want to know if I buy the projector if it will fit in the 92'' screen at the distance of 12' or at great hassle, 10. I have a hard time trusting those calculators when they said the panny wouldnt fit my room.
3D would be very nice, but it isn't necessary and I am willing to buy refurbished.
my stats-
