Well, I went out and got two Replays to replace my almost 4 year old 3080. I was really enthused. This is what happened, and a few questions at the end to see if anyone has tried this in order to get them to work.
I got a 5060 and a 5516. We have an in-house network (Cat6 cable) connected via an Asante 8 port 10/100/1000 switch which is connected to our broadband connection via a 4 port 10/100 router which is connected to the Comcast provide/maintained Cisco UBR905 device.
When the 5060 and 5516 were connected directly to the UBR905 they worked with a static IP. Plugged into the router, they worked with DHCP assigning an IP or a static IP in the 192.168.xxx.xxx range.
However, when they are connected through the 10/100/1000 switch they did not work - they couldn't connect to the net, couldn't get an IP address via DHCP and wouldn't work with a static IP.
There are 6 other machines of various types on the network all connected through the 10/100/1000 switch, some connecting at gigabit speeds, some connecting at 100-T speeds (e.g. some large volume web-servers, mail server,name servers and the like). There is also a little sub-network allowing connections via wireless also plugged into the 10/100/1000 switch, but I unplugged that during the test. I spent about 2 hours on the phone with ReplayTV, first with a nice lady and second with a tech guy (nice also) who called me back a few hours after I spoke with the first lady. We unplugged everything, reset etc although plugging several portables never required tha to get DHCP addresses in the past. None of it worked when they were connected via the 10/100/1000 switch.
Given that the other machines were working (running a variety of different OS's on different hardware) the conclusion that I reached was that the ReplayTVs are having some problems the switches since the computers here, plus various portables that people have plugged in over the past 2 years, have worked with these swtiches.
They looked really great and I have loved my 3080 for just a few months shy of 4 years, but want the broadband connectivity and in-home sharing. Since they couldn't get them working, I decided to return them and I got my RMA number.
After I got my RMA number though, I had another idea and thought I would run it by people here.
What I was considering was getting two cheap (e.g around $50) 10/100 routers and plugging them in right in front of each unit so that it would be:
Instead of:
Since the Replays were working when they were directly connected to the internet router, but not through the two switches I was wondering if this might work. I'd prefer NOT to have to do this, but it might be worth it to have them working (yes, I want this to work!!!).
So my questions:
1. Has anyone used any of the ReplayTVs with 10/100/1000 switches successfully?
2. Has anyone tried using a cheap intermediate router in the fashion described above?
3. After writing the above, I also tried connecting them through a 2-year old 10/100 switch and they didn't work with it either. This is kind of leading me to believe that perhaps they don't like being connected via a 10/100 switch unless I had two bad switches (or one bad 10/100 switch and a problem with the ReplayTVs on a 10/100/1000 switch) which seems unlikely since the other machines work quite well with them.
Instead of:
So my questions:
