The Definitive Technology SuperCube 2000 is an "ultra compact" subwoofer. the design leverages a 7.5 inch active driver and dual 7.5 inch passive radiators in a housing that measures 10.9" x 10.3" x 10.8", allowing you to place it in spaces where typical subwoofers won't fit.
3049065
The way physics works, the smaller the enclosure and driver on a subwoofer, the more power you need to achieve a particular output level. That is why this tiny little subwoofer is equipped with a 650 W amplifier. If big bass from a small box is on your agenda, here's a sub designed to deliver what you need. Now on sale on Amazon.com for $499, which is $100 off list price.
3049064
  • Huge bass performance from an ultra-compact enclosure
  • Delivers tight bass with musical accuracy
  • Class HD 650-watt power amplifier
  • High-gloss lacquer finish
