I'm most likely going with Martin Logan ElectroMotion speakers for LCR, and Motions for the surrounds, but still looking for a sub. I was considering getting the Grotto I for a sub, but then I read a bunch of reviews that if you want accuracy, it's great, but if you want it for bass thumping during movies, it's not so great.
Any subwoofer suggestions?
My room is about 14' x 20', and this will be using 99% for movies / tv.
With major output to 20 Hz in mind, I suggest the SVS PB-12 Plus:
Thanks for the suggestions guys, I'll take a look at them. And 1300 isn't too much more, all my budgets for this are fairly fuzzy, I'm willing to spend more if it's worth it.
You should be looking at two $500 subs, this will even out room modes. You also dont need to got ported in a room your size, a sealed box will pick up room gain for flatter response.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
AVS Forum
