I'm starting to get my PJ really dialed in and need help with a couple of problems I've had since the beginning.
I am using an Iscan v2 and a Dalite 72" wide 4x3 screen, squeezed to 16x9.
1. Images on Red and Blue tube faces are not sharp (I cannot see scan lines). I have set G2 (per BoyzToyz site), Contrast, and Brightness with Avia. I am going to attempt Astig adjustment next. Since there are only 2 pole magnets am I correct that I'm trying to achieve an even under focused pattern with no movement of the dots (or pluses) throughout the full range of focus adjustment? Are there any other adjustments that would affect tube focus? Red lines on the screen (especially vertical) are fatter and are visible on both sides of Green lines.
2. My picture is not square (rectangle). The right side keystone's down (top and bottom) to almost 2" shorter than the left. Also the left edge of the Red crosshatch pattern horizontal lines bend up slightly (see attached drawing which is over exaggerated). Screen and PJ alignment have been checked and re-checked several times (by more than one person) and appears to be correct. I have also checked to make sure all the floor/ceiling plugs are correct. Just to check, I have moved the left side of PJ forward and back up to 6" and re-centered image, without correcting the problem.
Both problems are irritating, but the 2nd one is driving me nuts.
Thanks, Jawhn
Thanks, Jawhn
