I am trying to set up my new 1031q with a composite input, the problem I am having is getting the vertical height of the screen small enough for a 16:9 screen size. I have minimized the vertical size control on the convergence board, and have adjusted the master v size pot on the da board per Larrys guide. The trouble is that the master V size pot seems to have no effect, I can turn it from min to max and I only get 1 scan lines worth of adjustment, I can actually see the scan line start at the far left and grow to the right as I increse the master v size pot. The image also seems to completly fill my raster, I used the white full screen from Avia, the only way I can get the image to not fill the raster is if I use the smaller window test pattern, is this how it is meant to be? I have the DVD player set to 16:9 screen, and this seems to cause some problems in AVia, menus looking strange and doubled up text, I checked this on a regular TV and I get the same result. Is avia enhanced for use with widescreen? Any ideas how to get my image to fit the screen vertically?
Dave
Dave
