Originally Posted by Mit07 /forum/post/0
Thanks for the nice summary. I'm mostly interested in PQ comparisons so I edited your list. Would love to see a side by side - where were you able to do this?
I'll try and expand on your key points, again just the impression I was left with based on the units I had in my setup, YMMV:
+Mits Better optics, its sharp edge to edge, big difference
Both Pearls I tried, suffered from blurring as you moved away from the center. I tested using a 1080p still frame signal. In the corners the blur or CA was much more noticable than on the Mits. The Mits had little if any, once I found the optimal horizontal shift position, it seemed sharp edge to edge.
+Mits Better Scaler / Deinterlacer big difference here with 1080i, 720P
This is something I never thought much about till I seen the Mits and the difference it can make. The Mits uses a new Silicon Optix HQV scaler/deinterlacer. I think you'd have to spend $2K-3K to get a stand alone processor like is built in the Mits. Menus on my ExpressVu (Dish) HD PVR looked sharp, crisp, 1080i HDTV football, Letterman, etc, the same, when I set the PVR to either 1080i or 720p. VGA out on the 360 looked sharper than Ive ever seen it, at 720p or 1080p. The Pearl on the other hand made those sources look soft, even blurry in comparison.
Now the Pearl is NOT a blurry projector, dont get me wrong, just in comparison to what I seen with the Mits. The Pearl looks similar to going to a movie theater, where I always seem to find the images on the soft side, some like that look.
Where the Pearl comes out on top is:
+Black level, big difference here
This here is the Pearl's Ace and why so many are very happy to own it.
The Mits was very weak in my setup with regard to black level. With the Mits if you put up a image where there is black in one area and light in much of the another, the iris opens and the black area looked 'screen white'. I could clearly see the screen and the border etc, it just lost the immersion experience. I think its because the Mits is brighter and its black level with the iris opened is much higher than the Pearl, so your entire room lights up, reflects and what should be black becomes screen white.
Now I'm using a high power screen , and the room has white ceilings both of those were working against the Mits, but in that room my old DLP has decent blacks and so did the Pearl.
+Dynamic Iris is much faster to react on Pearl
I never noticed the pearls iris, getting smaller for dark scenes to make them blacker and opening for bright scenes. I noticed every change on the Mits where it seems to take a second to react, it closes/opens slower. But this did not really concern me, the iris changes dont happen that often. It was the almost white blacks at times that i could not adjust to.
There may be optimal settings I missed on either projector, but I'm just trying to offer my unbiased view based on my observations. If one is planning to watch mostly DVD movies, those tend to often have many darks scenes and I think many might be happier with the Pearl, as sharpness is not much of a factor with DVD as they are low resolution to begin with. HD looks OK on the Pearl too, its just a softer more film like look, that didn't appeal to me being used to a crisper DLP image.
If your looking for a general purpose projector to play PS3 or 360 games on, to watch HD Sports, or use a PC with, and movies are not as important then the Mits will amaze you if you get one with decent convergence. The Mits I had looked sharper than even a Sharp 20000 DLP with bright 1080p still images, and I dont know how thats possible as the Sharp being DLP is pixel perfect.
Hope that helps, but be sure to compare or demo whatever you buy first, and draw your on conclusions, sorry I didn't take any images to post to compare
