Just a guess here. I wouldn't think cable problems would cause that 'only-16-color' effect. My only suggestion would be to triple check all the electronic menus involved in the setup. As I discovered with my Philips HDTV RPTV recently, a menu selection somehow changed by itself (HDTV format), which resulted in a unusual HDTV display (16:9 HDTV became ~14:9 with blurring of image edges). For that input mode, you clearly need a known 'good' signal source as a reference. But if you're saying in your last sentence that you haven't provided a complete ground path in your cable shielding, yes, that could cause serious signal problems!-- John
