Status
Not open for further replies.
1 - 3 of 3 Posts
Hi,
I seem to be having trouble getting 1080i inputs to show up on my Sony 36" FD Trinitron WEGA HDTV. I am using a DVI-HDMI cable running through my ATI Radeon 9800XT. 480p and 720p resolution work great with no problems whatsoever but whenever I move up to 1080i it results in a blank screen. I have updated my Catalyst drivers to the recent 5.8 version. Has anyone here had a similar issue?
Have you tried to use "force 1080i" from control panel or CCC?
Discussion Starter · #3 ·
Yeah I went through the settings and tried different combinations but all of them had the same results. I used to have a component cable converter and that worked fine. I decided to switch over to hdmi because the picture looked crisper and the colors were better balanced.
1 - 3 of 3 Posts
Status
