Hi,
been trying to configure my Pc for HD files but i can only watch HD trailers (MOV files) via quicktime without Stutter...
If i use zoom player pro (windvd 8 doesn't seem to be able to read those files) i get lots of stutter... i've tryed to config the player but without success for those files...
I'm running an AMD X2 4400 with 2Gb of memory and a Nvidia 7800GT card so don't think it's hardware related specially cause quicktime reads them fine...
Any Help?
I would like to use only one player for all media files if possible (i could use one only for DVD and other for the rest).
Other problem i'm having is that i installed Purevideo but i cannot seem to make it work...
In Zoom Player i have the NVIDIA NVDVD v3+ Video Decoder. Is this Purevideo?
Cause i select this one and when i play a DVD or other media file i don't get the icon on the task bar as i believe it should be...
Also, is there an option to use purevideo in some cases (hd files, DVD for instance) and FFDShow for the others? I disabled FFDShow to use purevideo but still don't have the icon on the task bar so i think i don't have it working...
Tryed WinDVD 8 ; Zoom Player WMV pro ; Media Player Classic and Windows Media Player and neither makes the Purevideo Icon to appear.
HELPPPPPPPPPPPP !!!!!!!!!!
Any Help?
