Paul -
Yes. That is normal. (Threw me at first too!)
... john ...
... john ...
Originally posted by John Bizios: Paul - Remember, that the lens is not centered on the projector housing, it's about 2+" off-center. The key for positioning is to make sure that the dead center of the lens is also dead center of the top edge of the screen material (if ceiling-mounted). I mounted my projector first, took careful measurements and then used those to position the screen. This, btw for me, turned out to be different than the initial throw onto the blank wall even though, like you, the geometry from AVIA looked good on the blank wall. My biggest problem was the piece of crap Sony mount which to this day prevents me from horizontally leveling the projector correctly. I've had to wedge a small piece of cardboard between the ceiling and the projector body to get (and keep) it level. Not pretty, but it works. Good luck - ... john ... [This message has been edited by John Bizios (edited 07-13-2001).] |
