If you're taking requests, 1.5 cu ft sealed.What did you guys want to see with this sub. What size box
Sorry for the long delay guys here's 1 sub in 4 different size boxes.If you're taking requests, 1.5 cu ft sealed.
If these model anything like the CS1214's (and IIRC they are basically clones just different dustcaps) they are best used in small sealed boxes. Ported boxes need to be in the 5-6 cubic foot range, minimum for a decent response. And at that size for a 12, you can buy a PA460 and build a VBSS which would outperform it I bet.4 of these drivers 1.5 cubic ft each 6 cubic ft total
So when looking at your graph, is the hz below the box size in the sealed boxes, is that as low as it will play? I am trying to better understand the graphs.Sorry for the long delay guys here's 1 sub in 4 different size boxes.
...but unfortunately the 3K is still pretty loud without a fan mod. I have a BenQ W1070 projector and the two compete quite well on the annoyance scale.
Going to install a quieter, slower fan in the Inuke over Christmas and hopefully not burn it up.
https://www.jbl.com/on/demandware.s...c68/pdfs/Technical data- CX1200 (English).pdfI was under the impression that these where the same drivers from what Matt posted.
this driver is the exact driver as the JBL CS1214 I just looked at both technical data sheets thanks for the link though
Cool beans! Good to know...this driver is the exact driver as the JBL CS1214 I just looked at both technical data sheets thanks for the link though![]()
Actual in room measurements...YES!real world comparison in my room of these subs ported vs sealed
the ported box is about 4.4 cu with a 25hz tune, the sealed box is about 3.3 cu.
I run two of these sealed.
I am surprised that the sealed has such a flat response across the sub-bass range. Yeah room gain! Still, giving up 6db in the lowest octaves seems like a big deal. If you don't need the extra output though I can see the allure of the smaller, simpler sealed build.
