I want to replace a blown woofer in my Def Tech Pro Sub 200tl. Do I have to use the exact woofer from the manufacturer or can I use any 12" woofer? I came across this particular woofer on SciPlus.com:
http://www.sciplus.com/category.cfm/...7/category/158
part #: 38718
but it's mentioned rated power is only 50 watts while the amp in the Pro Sub 200 is rated at something like 200 watts RMS. Do power ratings mean anything when it comes to subs? Will this woofer work or should I look at something else? Any help will be appreciated. Thanks!
part #: 38718
