1 - 13 of 13 Posts
Could someone let me know if I'd be getting too much of a good thing, so to speak, in this scenario? I'm looking to get a 120 inch screen and will be seated approx 12 feet away. I'd love a bright, contrasty image, but part of me is worried that this kind of size / distance might actually become painful.
Projector?
The answer is probably not. I run a 11'3" HP and view it from 13'. I'm using the BenQ PE7700.
Discussion Starter · #3 ·
Good point! The projector is a Sanyo Z5, which I just bought the othher day and am still jumping for joy at the image it's giving me when projected against a simple white wall!
We are running a Panny AX-100 on a 120" diag. HP and we sit 9 feet away from the screen with no problems. Please understand that we like sitting that close even though it doesn't fit the 1.0 or 1.5 screen width scenarios.
You could always add a filter to the PJ with the new lamp until it dims a little. Better to have too much brightness than not enough - the filter shouldn't change the image and it will add more time to your lamps useful life with a HG screen like the High Power...
Originally Posted by SixKindsOfWonder /forum/post/0
Projector?
A few years ago when I first looked into buying a HiPower screen, I had a similar question. Someboby (might have been Tryg) answered me that there is no such thing as a too bright screen.
Now after two HiPower screen (120") I agree with that person.
That's right. Have you ever seen a properly calibrated plasma and thought it was too bright?
I have a 115" high power and first row sitting is 9-10 feet away and its not to bright. It's a great screen, I'd recommend it to anyone.
Randy
Is that 115" diag, and thus 100"W, or is it 115" wide? If it's the former, then this is a viewing distance of 1.1 to 1.2 screen widths. This is pretty close. 1.5 seems to be the norm, though I'm planning for 1.3 (133" diag at 12.5 ft away).
115" diagonal
Originally Posted by Randito3 /forum/post/0
115" diagonal
Thanks for the reply. So you ARE sitting at ~1.1-1.2 screen widths; and I presume you like it, right? I'm plannning to get a 133" diag HP and sit ~ 12-13 ft away, which corresponds to ~ 1.3 screen widths. And I've been worrying about whether or not this would be too large for that distance! Your experience suggests that it wouldn't
One point (minor and probably immaterial to you depending on your viewing habits):
I have an HP too and the only time that I think it's too bright is when I have white subtitles on, and the particular movie is using a bright white for those subtitles. I don't watch a lot of films with subtitles on, but some folks do.
1 - 13 of 13 Posts
