1 - 4 of 4 Posts
i just bought a samsung 52in lcd model # ln52b610 i am confused on what setings i should use for the judder and blur do i leave them alone or reset them also what do i set the 120hz settings at
120hz isn't adjustable. It's always on. However, you can adjust the AMP (Automated Motion Processing) to whatever you think gives you the best picture, including OFF. Everyone's eyes are different, so you should play with the AMP settings to get the one you like. You may want to adjust it for different types of programming (movies, sports, etc.) or just leave it turned off.
1 - 4 of 4 Posts
