Status
Not open for further replies.
1 - 3 of 3 Posts
OK I'M calm now.
Last night after converging my pj,I decided to attempt to adjust the w/g and gain keys. Following the instructions only produced "not applicable" messages" I thought "duh", I need to be in serviceman mode. Well while holding down the test key waiting for the serviceman prompt (with active video playing on A input) the picture went blank and pj presented an error message on screen----( SW-ER1-5). then pressed A input and the picture came back but now whenever I attempt to enter serviceman mode, or press any other key that typically would respond with not applicable I only get a OFF message in the bottom RH corner where not applicable should be.
I can find no reference to this off message in the installation manual.
Somebody pleeeeeeeease help. Can,t enjoy the ball games till I get this off my mind:eek:
Discussion Starter · #2 ·
Never mind I figured it out.
Need to lay off the Michelob
Michelob! Dude, if you can afford Michelob, you can afoord a 8" projector instead of a 7"!
1 - 3 of 3 Posts
Status
