Status
Not open for further replies.
1 - 1 of 1 Posts
This issue has come up before and to be honest, I can't believe NO-ONE knows how to fix it. My 1272 has "wavy" lines when projecting any input, RGB, S or component video, but is razor sharp when started up without an input and viewing the start up screen or menu. I know the unit uses separate internal and external signal boards or processors for this but hasn't anyone figured out what is going wrong in this situation? Even if someone can just tell me which board the problem must lie in, I can try replacing it. I know of at least 3 other people out there that have the same problem and we all would very much appreciate it!
Thanks, Paul.
1 - 1 of 1 Posts
Status
