LIVE: Tech Talk Podcast with Scott Wilkinson, Episode 8 Click here for details.
Originally posted by kharvel 720 interlaced = 360 progressive. Lower than NTSC quality (480 interlaced) |
Originally posted by dandrewk Just curious - does the digital standard even allow for 1280x720 interlaced? |
do the newer ATI Radeon cards (9000+) have a default setting for 1280x720? |
Can anyone suggest to me what kinda timings on powerstrip I could use to run an older pj that scans 37hz max. |
Originally posted by trbarry It is a bit easier and more foregiving with my old G400 card to add most any resolutions within the horizontal refresh rate limits just using the Matrox utility. But my TV shouldn't go over 33.75 Khz, which limits me to maybe 540 or 544 lines. - Tom |
Originally posted by eggz I have a 9700Pro, and you have to use Powerstrip to get 1280 x 720. |
Originally posted by jkaiser ATI has some hidden resolutions, which I believe 1280x720 may be one of them. |
_____I have a spare g450 that I can use. So what am I lookin at? Is it possible to get something better than 540p and still be under 37khz.? How do I determine number of lines and how to reduce overscan if applicable? Should I just use the Matrox utility or use together with ps.? Any suggestions highly appreciated. |
