Status
Not open for further replies.
1 - 1 of 1 Posts
I have a scaler that outputs via a 15 pin vga connector (can be hooked to a pc monitor, I have mine on a plasma currently using a standard 15pin to 15 pin monitor cable).
I also have an older Zenith projector that takes s-video and has a "9 pin rgb" connector, which is a standard d-shell type connector.
My first thought was this was an old "ega" style pc monitor hookup and incompatible with the scaler. Then I saw some stuff about converting various vga/component/rgb inputs to a 9 pin connector, something called "video 3" or "input 3" or some such.
I searched high and low and couldnt seem to find the answer, so the question is: is there a cable that I can use to output the vga 15 pin output of this scaler to this 9 pin rgb input??? I'd LOVE to get the scaler on the projector.
Any help most appreciated.
1 - 1 of 1 Posts
Status
