1 - 15 of 15 Posts
Banned
Discussion Starter · #5 ·
Originally Posted by sound dropouts /forum/post/12949054
200 watts at 10 percent distortion....and the link you gave is for a 10 inch woofer....(edit...it also says 15 inch woofer...it cant seem to decide what it wants to be)
I wouldnt recommend it...
There are 3 different types. The 10" the 12" and the 15"
Here are the specs:
High Cut Frequency
50 - 200 Hz (Variable)
Power Requirements
120V AC, 60 Hz
Power Consumption (in Operation)
100W (Subwoofer)
Power Consumption (in Standby)
less then .3W (Subwoofer)
Frequency Response
Subwoofer- 20Hz-200Hz
Quantity (Packaged)
1 Subwoofer
Speaker Terminal Type
Line In & Line Out
Woofer Size(s)
Subwoofer- 15" (38cm)
Power Consumption (Subwoofer)
200W
Bass Driver(s)
Yes (Bass Reflex Design)
Level Control
Yes
Limited Warranty
1 Year Parts / 1 Year Labor
Weight (Approx.)
50 lb, 10 oz (16kg)
Dimensions (Approx.)
17 5/16 x 1 1/2 x 20 3/16" (440 x 495 x 512mm)
What do you think, is it a great deal? All of the reviews that I have read on it are extremely positive.
I use to rep Sony Car Audio products. Stay away from their speakers and subwoofers.
Ian
Originally Posted by Parafly9 /forum/post/12949347
For that price i think it's a great deal.
i just paid 370 for that Cadence sub which has 225 RMS and a 15" driver. I'm sure it's probably better construction but is it worth twice as much? dont know
The Cadence is far superior in EVERY way over the Sony sub. It is more then worth it.
I just ran across this sub on Amazon for $151 and was wondering if anyone actually owns one on here that can give a review of its pros and cons.
A friend of mine gave me his 12" sony sub when he moved since he didnt have the room for it.
I gave it back.
  • Like
Reactions: blake18
I have one and like it.
I've only compared it to Klipsch's cheaper 10 " sub. "synergy line'" ?
In my opinion the sony was definitely louder, and sound quality is pretty good too. I'm satisfied.
It's for sure not the best out there, but for the money its hard to beat. I'm considering ordering another one.
Klipsch subs aren't known for high output either. Its not really a good comparison. Check out something else in the price range thats a solid performer to compare them to.
For the money it is one of the BEST SOUNDING powered subwoofers I've owned.It will shake EVERYTHING in your house and on the walls including your neighbors house and there walls,people will hear and feel it several houses away.
1 - 15 of 15 Posts
