1 - 2 of 2 Posts
I just got an LCD TV and am trying to use with my computer. I don't have cable, so I would like to just use a PC for all my TV viewing. The TV is Sharp Aquos LC-40LE700UN. It's 1080p 120Hz, so it is a decent one and should be able to handle any reasonable input. My video card is Radeon 9600. Yes, it's old, but it supports 1920x1080. I am using a Monoprice DVI -> HDMI cable to connect them.
Anyway, I tried a bunch of different resolutions. All seem to work fine. For some reason 1777x1000 does not work at all, but that does not concern me. When I try 1920x1080 60Hz (which is what I really want to use), I get a ton of horizontal static. I can make out what is on the screen, but it's definitely far from watchable. The TV classifies the signal as 1080p, so something is right. I also tried 1920x1080 30Hz (interlaced). That works and TV appropriately calls it 1080i. So why is 1920x1080 60Hz not working?
Thanks in advance.
Many HDTVs HDMI receiver chips that will accept 1080p/30, or 1080p/24 will not accept 1080p/60 since it is not an approved ATSC resolution and requires twice the bandwidth of 1080p/30 or 1080i. Check your TV user's manual.
Since it is a new TV there is no reason for you to try and send it an underescanned resoolution since it has the abilty to eliminate Overscan with 1:1 or dot for dot display mode.
1 - 2 of 2 Posts
