1 - 2 of 2 Posts
Hi guys,
I just ordered a Sony HT-CT500 soundbar. It hasn't even arrived yet, but before I bought it I was on the fence between getting that and a decent 2.1 system. Does anyone have any suggestions on a 2.1 system I could compare it to? I spent $389 on the soundbar, so I would need the price to be less than or equal to that. I had interest in the Klipsch CS-700, but it's a little bit out of my price range. I'll probably buy a 2.1 system, try both that and the CT500 in my house, and keep the one I like best.
Thanks for the help!
Lots of bookshelf speakers that you could try.
Energy C-200
http://www.audioadvisor.com/prodinfo.asp?number=ENC200
Energy C-100
http://www.audioadvisor.com/prodinfo.asp?number=ENC100
Polk Monitor 40
http://www.newegg.com/Product/Produc...82E16882290010
Home Theater Direct Level Two
http://www.htd.com/cabinet-speakers/...shelf-Speakers
Infinity Primus 162
http://www.vanns.com/shop/servlet/it..._c=site_search
Then add a subwoofer around $200.
http://www.amazon.com/BIC-America-F1...543216&sr=1-17
I'm pretty confident any of those speakers plus the sub would blow away your soundbar....
1 - 2 of 2 Posts
