Status
Not open for further replies.
1 - 5 of 5 Posts
I have a new 4504 and am considering a drive upgrade. I am going to wait a couple of weeks, but wanted to get answers to two questions first.
1. Can you put 2 drives in this unit easily?
2. Can I use the original 40GB and buy an 80GB for a total of 120GB?
Answers:
1) Yes but you will need to fabricate or buy a mout for the second drive
2) Yes but you will need to fabricate or buy a mout for the second drive
2. I don't think I'd bother for just adding a 40?
You're much better off with one large drive than 2 smaller ones. Less problems that way.
Get a 120 GB and use that?
The mount is custom. The mount that comes with a HD is meant for a computer, not a DVR. Of course, you can make your own mount cheap or buy the custom on the net for about $20 with the customer power cable.
I would do as KenL advised. Go with one larger drive and forget the 2-drive upgrade. Use the 40 GB in your computer.
1 - 5 of 5 Posts
Status
