I'm looking to someting different with my Zoomplayer setup. I have 2 sound cards active on my PC (Internal SoundMax and a Revo) and I would like to hook headphones to the SoundMax card and listen to movies that way at night. However, I have been able to configure zoomplayer to play sound through both soundcards (at differnt times, obvioulsy) without a problem. I just have to go in each time and change the soundcard that zoomplayer is using. I then thought that If I had 2 zoomplayer directories saved the diffent setup for each one, I could just launch the correct zoomplayer.exe and not have to worry about changing the filter setting for the different sound card. This doens't work, though. No matter which .exe I launch, Zoomplayer always remembers its last fillter settings. Is there any way to be able to auto launch 2 different filter settings on zoomplayer so I dont have to change the audio card I want to use each time?
