Status
Not open for further replies.
1 - 4 of 4 Posts
Looking at getting either a 51S500 or 57S500 (first choice)
Getting it into my apartment might be a bit tricky, as there are 2 90 degree turns right near the door to get into my place. Would it be a bad idea to split the cabinet on either of these? The 51 might go no problem in one piece, but the 57 might not make it. I want to go as big as possible.
I am going to measure it up and see if it will work, best as I can, but am concerned about splitting the case.
Any input?
thanks
Splitting the cabinet is annoying, if easy.
The biggest issues are:
gently handling the top part to avoid cracking something
unplugging the internal cable... for some godawful reason they put the plug to be unplugged after a bunch of (capacitor/transitor/thingies on two wires) on the board, so that plug the latch, you have to be real careful not to snap one off.
1 - 4 of 4 Posts
Status
