1 - 3 of 3 Posts
Hi everybody
I'm soon to build a pair of monitors using Dayton RS-180-8 drivers, haven't decided on the tweeters yet. Now, my query is this, I will be using them with a separate active sub but not all the time. Is there a way to high cut the monitors' low fq when using them with the sub but set it back again for use without the sub? I've had a look at active x-overs and also equalizers but everything has pro and cons and my head is spinning
Maybe it's a silly question but I'm a bit new to this. Any help is appreciated.
With a AVR you can use bass management in straight 2ch mode or not use it in 'Direct' mode.
So yes, you can change at a push of a button.
1 - 3 of 3 Posts
