I've decided to build a MBM and split my sub stage into a two way config. However, I'm hoping to get some tuning advice as I'm completely new to this.
Current system:
Processor: Emotiva Fusion 8100
Mains: Goldenear Trition 5's
Center: Goldenear Supercenter XXL
Surrounds: Goldenear Invisa 7000 In-Ceiling
HF amp: Crown DCI 8/300 (300w rms x 8 at 4 and 8 ohm)
Subwoofers: 2x SI HT18D4 (v1) in 4cf flatpacks. (will be upgraded to HST's, black friday sale maybe?)
Sub amp: Crown DCI 4/1250 (1250w rms x 4 at 2, 4, 8ohm, 2500w rms x 2 at 4, 8, 16ohm bridged) (20a Dedicated circuit)
Additional Sub: Goldenear Supersub XXL, nearfield behind MLP (hopefully not permanent here, looks horrible and takes too much space)
Usage is 90% movie, 10% music
Due to my relatively small mains and VLF subs, I have a significant response gap from 50hz to 120hz, just from running sine sweeps.
I have a minidsp 2x4 bal and omnimic, just haven't had time to set it up yet. I'm pretty sure EQ can't fix this issue though, since the Crown amp will be more than capable of melting down HT18's at higher frequency.
I started playing with the idea of adding 1-4 PA460's as MBM's, either nearfield behind main seats, or on front wall under center. Most designs just take up too much space for my setup though. Then I started reading up on specs and box recommendations for higher end PA drivers. I discovered the B&C 18DS115, which wants a 3.5cf box at 40hz.
So I ordered a the B&C 18DS115 and a blank baffle 4cf flatpack from PE. I plan to mount the woofer off-center toward the top of the baffle, leaving space for a 2" slot port at the bottom.
My two HT18's are set up on the front wall under the screen, on either side of the center. One will be moved to the back of the room, with the MBM in its place to keep the symmetrical appearance.
The HT18's are currently bridged on the crown, avoiding input sensitivity mismatch mostly. With the addition of the miniDSP, I will set them up on 1250w channels, with a 2500w bridged channel left for the MBM.
When I upgrade to HST's, I will get an additional amp. Crown 2/1250 or 4/1250. 2500w rms available to all three subs. Hope the 20A breaker can take it.
My mains are currently running to 80hz, will change to 120 or 150 with the addition of the MBM.
Sorry about the book, but I believe too much information is better than too little.
TL/DR: I have 2 SI HT18's sealed in 4cf flatpacks. I'm adding a B&C 18DS115 in another 4cf flatpack, ported at 40hz. I have plenty of amp for all three.
Does anyone see any problems with this setup?
How about crossover recommendations for the two way sub setup?
Is the 40hz port tune optimal?
Chris
Current system:
Chris
