Status
Not open for further replies.
1 - 7 of 7 Posts
I own 2 Harman Kardon Signature amps...a 2.1 & a 1.5.
They both have puny ungrounded power cords. The 2.1, which has the most current draw, has the smaller cord (beyond my understanding as to why).
I know for sure I am going to install bigger cords. Should I just replace the 2 wire cords, or add a sheilded 3 wire cord & ground it to the chassis? If the later, can someone provide some links with pics as how to (PROPERLY) do so?
A couple of thoughts:
If they needed a ground, they'd have come with one.
You can't judge a wire by it's cover; what's the conductor gauge?
For a ground, a separate single wire works as well.
Okay, three thoughts.
Discussion Starter · #3 ·
The smaller wire is 18g(for sure), the larger is 16ga(or 14g.).
I want 12g. for both.
They're good for about 7 and 10 amps, respectively. I'd go with, say, 14-ga. wire, but I'd experiment with a temporary ground wire first; you might get loop-induced hum.
Discussion Starter · #5 ·
Since they're noise free, I'd better just stick with larger 2 wire.
Agreed; if it ain't broke, don't fix it.
Do, however, keep the polarity the same.
Discussion Starter · #7 ·
No doubt!
Thanx!
1 - 7 of 7 Posts
Status
