Status
Not open for further replies.
1 - 5 of 5 Posts
Discussion Starter #1
Hi - I am looking for an LCDTV in the 20-25" range for a kitchen counter application. It would be very nice if I could find one with a built in QAM tuner. HDTV/Cablcard not needed.
Does anyone have any recommendations?
Let's just double check what kind of tuner you'll need -- if you want to watch regular analog cable, an NTSC tuner is what you need. The QAM tuner is for digital cable channels, but it isn't particularly useful without a CableCard, since almost all digital channels are scrambled on most cable systems. At this time CableCard is not available in sizes under 26.
Discussion Starter #4
Hi - Like I said, I am looking for a QAM tuner. For this kitchen counter application all I need is the unscrambled digital content.
Cablecard would be nice, but it is not required.
Okay then, the smallest models I know of with QAM tuners are Sharp 26 and LG 26. They also have CableCard. Best of luck in your search.
1 - 5 of 5 Posts
Status
