Out of curiosity, why does it need to be a 20 amp model?
Well I have a dedicated 20amp line so figured I should be taking advantage. No?Out of curiosity, why does it need to be a 20 amp model?
Great spelling!@classic_erik, this Erik #2, as Mike said, do you just need 10 outlets on a single 20 amp circuit?
Hum i think is from non-grounded outlets in the chain or the always noisy cable runs/cable boxes.
Taking advantage of what exactly? Just because the circuit happens to have a 20amp breaker doesn't mean you specifically need a 20 amp power conditioner. I run a pair of APC G5BLK 9-Outlet power conditioners and an APC J25B power conditioner with battery backup on a 20 amp line.Well I have a dedicated 20amp line so figured I should be taking advantage. No?
Power is not my strong suit, but I was thinking that if I have a 20 amp outlet, my equipment could pull 2400 watts of power from the line, where if I broke the chain and used a power conditioner with a max current of 15 amp I decrease my supply down to 1800 watts. Apologies for my naïveté!Taking advantage of what exactly? Just because the circuit happens to have a 20amp breaker doesn't mean you specifically need a 20 amp power conditioner. I run a pair of APC G5BLK 9-Outlet power conditioners and an APC J25B power conditioner with battery backup on a 20 amp line.
Here is my set up:@classic_erik, EDITED
Hey Erik this is Erik, can you list what you are putting on that 20 amp circuit?
I have been using a monster power strip for 14 years without issue, like THIS
1. Do you live in an area that gets lightening? That is a big one to address.
2. Hum and noise are almost always introduced from non-grounded outlets somewhere in the chain and/or long coax cable runs/cable boxes.
Is there a particular surgex model you suggest?If you're looking for surge protection, there's nothing better than SurgeX. All MOV based units degrade over time and fail.
Here's that APC linked above taking 6k volts and 6k amps compared to a SurgeX:
That is why I suggested a mains panel protector. Surgex does nothing for other power problems.Is there a particular surgex model you suggest?
Check out something like Panamax M5300-PM 11-Outlet Home Theater Power Conditioner. I use these.Hey guys, I’ve been looking for a reasonably priced 20 amp power conditioner. I don’t have a rack so the options are extremely limited and expensive!
I am not completely bought into the benefits of noise reduction / video enhancement, but I need at least 10 outlets and there are no basic surge protectors out in the market in a 20amp configuration. I’m basically forced to either buy 2 Leviton surge protection 6 outlet strips for about $200, or a Furman Elite 20 PFI 12 outlet power conditioner for about $750 (or around $500 used on eBay). I suppose there has to be some benefit but spending an additional $300-$500 over the Leviton surge protectors is crazy to me.
Am I missing something? Any other ideas or power conditioner brands?
I use this exact model. Works great!! I would highly recommend that one as well.Erik Look into this apc theater part. Works amazing. Never seen a bad review. I have 2 of them and it will use all the power u can feed. Audiholics reviewed this model and uses it.
Amazon.com: APC H15BLK 12-Outlet H-Type Rack-Mountable Power Conditioner: Home Audio & Theater
