Status
Not open for further replies.
1 - 4 of 4 Posts
· Registered
OK, here's the scoop.
I just finished building my new HTPC and have all the software just how I want it and BAMM! my 3 month old IBM Deskstar 60GXP hard drive craps out on me. Luckily I have a fairly recent ghost image so no problem, or so I thought.
I can take the ghost image and load it down to another drive and 2000 boots, but it gets stuck in a loop telling me that the paging file is missing or too small and that I should make it bigger. The trouble is that I can never get past this message to make it bigger.
Would there be a way to create a paging file via a dos prompt. I can boot to dos quite happily? I have tried safe mode, but that gives the same result as does last known good.
Hopefully someone will have the answer before I decide to satart from scratch again.
HEEEELLLLLPPPPP
· Registered
I can think of one way:
Boot from the CD and run a Repair. Not the Repair console, but a repair of the installation where you have to use the 'R' key.
but that is a pain and you would have to reinstall SP2 (if you have an older copy) patches etc.
Here is an idea:
http://support.microsoft.com/search/...;en-us;Q255205
And stop at step 3, before you delete the file. Just leave it that way and exit the repair console.
It might just work . . .
· Registered
While the BIOS is booting, keep tapping the F8 key.
A menu will appear.
Select "Safe Mode" boot.
Win2k will boot into safe mode, and you should then be able to change the virtual memory settings.
gluck,
-anders
1 - 4 of 4 Posts
Status
