10001 - 10020 of 15059 Posts
Ok, after some time debating, I pulled the trigger today. I was completely set on going with the 56" version of the 87 series, until today. I found a site that currently is selling the 89 series 56" for basically the same price of the 87. I know direct links are frowned upon here, and it's probably best off that I get a shipment confirmation and delivery before I post the site, but I'm pretty excited. The site is listed with the BBB (no complaints), and is an authorized Samsung reseller, so I hope it's legit. I called them and confirmed everything before ordering, and they did confirm the price.
I'll post more info as it develops. Right now, I just have a purchase confirmation email.
Matt
I decided to poke around the firmware to see if there was anything interesting. I downloaded 1026 and unzipped it, poked around with a hex editor and found that these sets run embedded linux as an operating system. So I mounted the various img files and browsed around and found lots of neat stuff. As long as the hardware between the 87's and 89's are the same(wouldnt surprise me) I am sure someone could probably take the firmware from an 87 and firmware from an 89, compare them, then make an improved firmware for the 87 that enables the extra features of the 89....
Mike
Premium Member
56 or 61? Yes I have seen the recommended viewing distance charts, but what about this TV specifically would you recommend? I have 8-10 feet. Thanks
Justin
Nice work Mike... very interesting. However, the post below strongly suggests that the hardware is different:
Originally Posted by jonny_H /forum/post/10335792
For those still thinking the 87S has HDMI 1.3, I don't think it does. UMR has pointed out that these sets do use different chipsets.
[Missing 3 Important Quotes]
Also, there is also no mention of xvyCC in the HTLxx87S manual. I've seen a screen shot of the 89S setting where you can turn it on, and it's not there on the 87S menus. Even if the innards are actually 1.3, they've at least turned it off via firmware in this regard.
Read the Full Post:
http://www.avsforum.com/avs-vb/showt...2#post10335792
Avio
Mike
No one here has posted firmware for xx89s series. The xx87s firmware is at 1028 I believe (1026 was posted), while xx89s firmware is at 1014 I believe. The firmware isn't cross-compatible, but its a good way to totally hose your display if you want to be the guinea pig.
Originally Posted by nc88keyz /forum/post/12961128
Um...lets not hack our firmwares on a DLP.
Is it really sought after?
What could possibly go wrong? . . . No TV, No Warranty, and very POed wife!
Holy crap.. What a thing of beauty!!
I just brought my 6189S through the front door, now I'm starring at it here in the kitchen waiting for the wife to get home so I can put this on the stand and fire it up.
My 52" LG projection LCD(now 4-5 yrs old) is now going in the bedroom
Originally Posted by JohnAV /forum/post/12961191
... while xx89s firmware is at 1014 I believe. ...
At least 2 posters in this thread who are xx89S owners have mentioned the existence of ver. 1019 for the xx89 series. If you "Search this Thread" for "1019" you can find those posts.
Avio
Well I am an electronics tech, at work we have all types of programmers, so if I did mess with my tv and it went to hell I could pop it open and reprogram the chips directly back to factory original....but i have no interest in being a lab rat lol. I was just tossing it all out there in case there was someone so inclined to take on the task/risk involved.
Mike
Here's the most believable post confirming that v. 1019 for xx89 series exists:
Originally Posted by Stormwind /forum/post/12415710
A tech just worked on my HL-T6189S ...
Something interesting: the new mainboard has a date of 2007-09-21 with a firmware version of 1019 ("MODULE: T-LAU2AUS0-1019, DATE: 2007-09-21, MICOM: T-DLEDAUS5-3029").
Avio
Avio
Your right!
See page 289 of this topic.
I'm still simply wondering what is the difference between the 1026 and 1028 firmware and the earliest ones. After upgrading to 1026 on my set, I have found absolutely none.
I decided to poke around the firmware to see if there was anything interesting. I downloaded 1026 and unzipped it, poked around with a hex editor and found that these sets run embedded linux as an operating system. So I mounted the various img files and browsed around and found lots of neat stuff. ...
Mike: I'm not interested in hacking the xx87s firmware (and also not able to)... but I'm curious about the "neat stuff" your exploration revealed.
Could you post the most interesting stuff you discovered, or, alternately, could you provide a zipped data dump or "screen shots" of the img files. I do not know if we are talking about graphics, text, source code or whatever.
Can you show us what you found, even if highly technical, or so-called gibberish, or "Greek-to-Me"?
Thanks. Avio
Banned
Have 1019 on my 6189S.
The only way I'd consider looking into 3rd party firmware is to make sure you can go back to the default incase you need any service issues. Having a hacked firmware would more than likely void the warranty.
Doing firmware updates for stuff is not that unusal these days.
What I'd like to see as well is what types of things can be changed/tweaked/etc.
Unless we could know what is actually available for tweaking its hard to say what the value would be. Changing a color of a button would hardly be worth the risk. Adding full support for 24fps, well I might think about doing that. Not sure I would but I would at least think about it. Or change the behavior of the analog ins on HDMI3 so that you could use them no matter what, turn on dd 5.1 pass through, make sure audio out analog jacks were variable, stuff like that.
Edit: Just as a general comment I'm surprised we haven't seen hacked firmware already for stuff like these TV's or the bluray players, etc. With the knowledge and skill set of folks "out there" my guess is there probably already are hacked firmwares but they aren't just laying around for us common folks to find.
DirecTV sent 2 more guys out and they still couldn't fix the problem so I'm heading over to Comcast now. Anyone have feedback on how HD looks on their 5687 with Comcast HD?
Also, even with Blue-Ray now I'm noticing some flickering on the darker scenes and with certain camera angles...I'm assuming this is the TV. Can I fix this myself or should I do a return/exchange for a new one?
Really wish the delivery guys were more competent so I didn't have to drag this one back in... After seeing them ramp over speed bumps and swap out my TV for a smaller broken one at first thinking I wouldn't catch them, there's no way in he** I'm trusting them.
Well the img files are basically like iso files for cd's. It is basically the "disc" copied bit by bit into a file. Under linux you can mount such file systems as if they were the actual "disc", and then browse through them just as you would a cd, usb drive, or hard drive. So upon mounting the img files I was able to browse through what windows users can equate to as the tv's "c:" drive. Basically all the linux config files are there along with the standard executables and what I would assume are the binary drivers for several of the tv's systems(display, sound, i/o). One of the files(exe.img) contains what appears to possibly be the main program for the tv....not sure though.
This stuff is mainly of use to someone with the time to reverse engineer the various drivers and compare them to the 89 series. Hardware comparison would also be important. Once you know how everything works it is easy enough to change as you see fit. Since it is linux you could even make your own programs to run on it rather easily. It is running MontaVista Linux pro 3.1, kernel 2.4.20, they appear to make linux distros for various embedded applications including set top boxes.
Custom firmware is always fun, I have an older htc pocketpc phone that people reverse engineered and made a tool where you can customize the firmware through their web site, download the firmware image it produced, and burn it to the phone....very cool.
I can talk geek all night....but i will save you all from that.
Mike
Originally Posted by tfbit /forum/post/12959757
The problem you will find with placing your center channel in front of the TV is that it will probably obstruct the IR receiver that Samsung thoughtfully (being very sarcastic) put in the center of the round on/off button in the center of the set.
On my set (HLT6176), the IR sensor in on the light engine which means it gets it's signal through the screen! Maybe yours is too, easy enough to check.
