Status
Not open for further replies.
1 - 20 of 42 Posts
Hey folks,
Bought my 2012 ST-50 (50") on Nov. 30, and I love the set. Fox News is one of my favorite channels, so I've been watching it quite a lot.
A couple of days ago I was watching something that had a full white screen for several seconds, and I noticed a slight "shadow" in the bottom left corner of the screen. Since I bought the TV, I've done a lot of reading on this site and others about PDPs, so I know about IR and burn-in.
The "shadow" is slight, and only visible when whatever content I am watching briefly displays a uniform color in that part of the screen. The shape of the shadow does seem to correspond to the shape of the Fox News logo that is ever-present on their broadcasts.
Even though the logo rotates, it's not transparent. (I understand that transparent logos are less likely to cause IR and burn-in.)
I've been using D-Nice's recommended settings for ST-50s that haven't run the slides.
My question is, can I expect the shadow to eventually go away if I watch full-screen content and stay off Fox News Channel? Is there anything else I can do to get rid of this? As I say, it's very minor at this point, and no one else watching the set would likely notice. But, now that I've noticed it, it is a distraction to me, because I'm constantly looking for it.
I wish Fox would go to a transparent logo to reduce the risk of this for their viewers. I love Fox, and I would say, prior to discovering this problem, I was on Fox probably at least 60-70% of the time that the TV was on.
Do I have to permanently stay off Fox News Channel and other national news networks now? I hate that I paid this much for this PDP and now it may not only be damaged, but I may have to stay off one of my favorite channels.
Any other suggestions? Comments?
OK, so aside from the obvious suggestion to get your news from other sources....
The reality is what you're almost certainly seeing is temporary and not permanent. The more you watch things that aren't Fox News, the less visible the logo will become.
You could do any or all of the following:
1) Watch other stuff, preferably lots of other stuff... Normally, you can probably watch a single channel with a logo for something like, I dunno, 25% of the time without it getting retained. Since you are at more than 2x that according to your guesstimate, the retention will be a bit more stubborn.
2) Hit the Zoom button when you watch Fox some of the time so the logo moves somewhere else. The logo will split its time this way and be less "retained" in one place.
3) Really focus on not paying attention to it
4) Leave the TV on other content (preferably without a corner logo) when you aren't watching. The more time the TV spends not on that channel, the sooner the logo will go away
5) Try lower brightness / contrast settings, perhaps a somewhat brighter version of the "eco" mode on the TV (which is too dark). If you are at lower than normal settings, the retention will be reduced. Only use that setting when watching Fox News.
Now, that said, if you really watch Fox News that much, then 2/3 of the time, the logo is actually on so it can't really be bothering you that it's "retained". That's a good ratio of not being bothered, I'd say.
On another note, politics aside, Fox News spends a lot of time agitating its audience, getting it angry about stuff "those Democrats are up to." It might be a good thing for your sanity to just watch less of it anyway so that you aren't always so angry about whatever they are angry about today. I'm not say change your politics -- that's really up to you -- but if you watched less Fox News, you'd probably end up better able to calmly discuss your beliefs with people and more open to questioning specific things in them. And really, that's always a good thing. (See my signature in this post and the guy who wrote the quote for more on that.)
Discussion Starter · #5 ·
Thanks for the responses. I guess I had assumed it had to be burn-in, since it's been a few days since I first noticed it and its still there. Maybe I just haven't given it time to resolve.
I have to admit, it is VERY slight, and totally un-noticeable unless, as I say, the screen happens to display a solid color in that bottom corner. Even then, it's not noticeable unless the picture moves. Then, there's just a small, stationary shadow effect.
So, you guys are of the opinion that it is just temporary IR?
I have been staying off FNC, and I will post updates on this thread on the problem.
Banned
I recommend Fox Business (I can't recall if they have an intrusive logo because I don't watch tabloid cable news infotainment anymore). Whatever you do, stay away from MSNBC and CNN (pretty sure they also have those nasty logos, though that's only one reason from a long laundry list to avoid them
Premium Member
Originally Posted by john pifer  /t/1462756/2012-st-50-burn-in-from-fox-news-channel-logo/0_60#post_23069620
If it's that slight, yep, mixing up your viewing (actually everything Rogo said, especially with regards to taking down the brightness and contrast) should help. Then while you're watching other stuff try and ignore that area.
Originally Posted by john pifer  /t/1462756/2012-st-50-burn-in-from-fox-news-channel-logo#post_23069620
It's my opinion -- based on the science of how the display works -- that it's in fact "temporary image retention". But that said, even something that's temporary can be stubbornly persistent. I don't know precisely how long you've been running Fox News, but let's say 5 hours a day for 3 months and that's about 2/3 of your viewing... So it turns out because of the reliability of the logo being there, it could really take a while before all traces of it disappear. Eventually, more mixed viewing -- and some of the other ideas -- should preclude it from recurring as a persistent element.
Since it's so subtle, it'll probably become even more subtle over a shorter period of time.
I actually think that, if anything, this point outs how non-serious the concerns around burn-in really are. I realize others will draw opposite conclusions.
I have the Fox News logo basically burned in to my P42S1 plasma too, so you're not alone. I didn't notice it and identify it for the longest time, so when I finally did it was pretty much stuck their. The good news is that unless it's a screen of all one color, like a commercial, I would never notice it during regular viewing.
I also watch a lot of Fox News, and when we are gone we leave the TV on for our pets. Since the Fox News logo rotates I thought it might be a bit less susceptible to burn in. I was incorrect.
Originally Posted by rogo  /t/1462756/2012-st-50-burn-in-from-fox-news-channel-logo#post_23068959
Just gotta say, with a preface of "politics aside", this sounds about like politics exactly.
  • Like
Reactions: john pifer
Originally Posted by john pifer  /t/1462756/2012-st-50-burn-in-from-fox-news-channel-logo#post_23067346
Unfortunately, channel logos continue to be the bane of a PDPs existence to this day. I own a 2005 Panasonic PDP w/many 1000s of hours of operation that is still susceptible to persistent image retention of a channel’s logo if I watch one station too often.
The only way I know to reverse this kind of image retention is to:
1) Avoid watching that particular channel
2) Run full screen content w/o logos whenever possible (e.g. movies on HBO)
57 years of life leads me to believe that by-and-large FOX News provides the most honest coverage regarding the issues we face today. Unfortunately, with their omnipresent logos and crawling news ticker FOX is one of the least PDP friendly TV broadcasters.
(“Show me a young Conservative and I'll show you someone with no heart. Show me an old Liberal and I'll show you someone with no brains.” - Winston Churchill)
I've got an extremely faint History channel logo retained on my 65ST30....maybe watched the channel 1-2 hours per day. I have not tried removing it as it' s barely perceptible even when looking for it on a white background, but I did use slides when not watching my set during the direct 500 hours or so and it still happened to an extent.
Originally Posted by 9179mhb  /t/1462756/2012-st-50-burn-in-from-fox-news-channel-logo#post_23070702
I am pretty sure you can get more accurate news from Comedy Central and no IR from their logo to boot, but what do I know I have only been around for 36 years
Originally Posted by chifanpoe  /t/1462756/2012-st-50-burn-in-from-fox-news-channel-logo#post_23070755
Didn't you read the quote by Winston Churchill? I believe that explains it all.
Trust me, young man, eventually you will change your opinions.
Why I'm so old I can remember watching Black & White TV w/only (3) channels available.
(Hey Verizon FiOS... give me The Blaze TV)
My Grandma is 85 and prefers Comedy Central. So that settles that.
It's funny this came up. Having a PDP I have stopped watching 'news' channels for the most part. Plus, it's nice not having programming on that's 'yelling' at me - one way or the other.
'News' Channel IR was a concern when I got my PDP - my wife likes to watch a few of those kind of shows. So far it hasn't been a concern.
My other concern was the sprout kids channel…lots of 4:3 content. So far so good. I just have to remind her to hit the p-size button and stretch out that picture from time to time.
Originally Posted by 9179mhb  /t/1462756/2012-st-50-burn-in-from-fox-news-channel-logo/0_100#post_23071065
Life lessons from a self proclaimed "old man" on internet AV forums, post of the day!
Other quotes from your so "culturally" relevant Winston Churchill - " I do not admit... that a great wrong has been done to the Red Indians of America, or the black people of Australia... by the fact that a stronger race, a higher grade race... has come in and taken its place."
I hope one day I too can be cynical enough to think Fox News is filled of real news stories. By then OLED will be at a standard Plasma TV price points and we can reminisce over the good old days of CRT TVs and 480i images over the rabbit ears.
Originally Posted by boondongle  /t/1462756/2012-st-50-burn-in-from-fox-news-channel-logo/0_100#post_23071170
My - Pioneer, LG, and Panasonic Plasmas have all three made it through Sprout, Nogin, Disney Jr, and Nick Jr with my 2 year old and 6 year old sense 2006 with no issues of IR on any of them.
Banned
Originally Posted by chifanpoe  /t/1462756/2012-st-50-burn-in-from-fox-news-channel-logo#post_23071238
Yea, Margaret Sanger, queen of Planned Parenthood, had some pretty interesting thoughts on eugenics and undesirables as well.
And by the same token, Comedy Central isn't any more "real" than Fox News. They just appeal to your biases, like all of the aforementioned networks.
Hopefully you're as good at math as you are with trading the barbs because then you'll acknowledge with nearly $17T of US debt, increasing at a rate of $1T per year, is unsustainable.
With Bernanke's monetary policy that OLED you want is more likely to set you back $100,000.
I refuse to be held accountable for the sins of our forefathers, but if it wasn't for the sacrifice made by the WWII generation you would not be enjoying the life style you have today.
(If you can call living in your parent's basement and waiting tables at the TGI Friday's a life style)
1 - 20 of 42 Posts
Status
