1 - 2 of 2 Posts
Discussion Starter #1
Hello Everyone, I am new to the avsforum. I have a issue going on with my 2017 Vizio soundbar 3651-e6 model I purchased in the begging of 2018. It was working fine until just recently I made a huge mistake to connect my soundbar to the smartcast app and then it updated a firmware to 1.0.8.1 not sure what it was before. After the update equalizer Direct has so much bass that it feels like as if it is full. And all the gaming systems play so loud even on low volume. Now I cant turn to old firmware or even return it. If someone came across this problem I would highly appreciate a solution or your calibration settings after the firmware update to make the bass back to normal again. Thank you!!
Having what may be a similar issue with my sb4531-d5. Do you find that background noise is much higher than before the update as well? I’ve tried all the usual stuff, currently trying a whole bunch of random stuff lol. I’ll let you know if I come across anything.
My setup is:
Vizio P65-E1
Sb4531-D5 (ARC)
Xbox One x (hdmi 5)
1 - 2 of 2 Posts
