No price talk allowed in this thread - but I can point you in the right direction.Ah I see. Sorry your package is outside of my budget.
What is the lowest realistic price to put a package together to do SDR Autocal only? 90% of my display use is gaming in SDR and watching SDR content.
You can autocal with MobileForge which is a free application. The issue you may run into is that the device running MobileForge may not output bit perfect HDMI. From what others have said, the Amazon FireTV Stick is likely your cheapest option that is compatible with MobileForge and can output bit perfect HDMI. Your other option is to buy a Raspberry Pi and download the Pattern Generator software made by biasi. You can find out more about that software here (use Google Translate to read in English): http://www.avmagazine.it/forum/88-c...lay/301272-rpg-rpi-pattern-generator-by-biasi
So then at that point you would need to buy a Spectracal C6, the cheapest option would be a re-certified C6 from Spectracal - https://store.portrait.com/meters.html
You can buy them used off of eBay too but I found the meter I bought off eBay to not be very accurate. At least the re-certified one from Spectracal is known to be within spec.
Lastly you need to buy the Calman Home Enthusiast software from Spectracal directly. https://store.portrait.com/software/calman-home-enthusiast-with-add-ons.html
