7581 - 7600 of 16070 Posts
The current public version is 03.60.19, so it is very possible that the next public version will be 03.70.xx. There may never be a public version higher than 04.70.05, though there may be beta versions higher than that.
No. As said in my previous post, 04.70.05 has already been publicly released. The risk of the version never becoming higher than 04.70.05 is zero.
I agree with everything said here. I did it while under the impression I could downgrade like on the C6, but I'm stuck for now. It seems I got lucky this time, since 04.70.05 is already out in Korea, but I was scared there for a minute. I don't think I'd take the risk again, knowing what I know now.
I wonder if the European engineer version of 04.70.05 is identical to the Korean one.
If I understand GSYNC correctly, since the display will only do GSYNC 40-60Hz right now, we would want to cap our FPS to 60 in the drivers?
Alternative, could enable VSYNC but that means VSYNC will overwrite GSYNC whenever you are at 60FPS (99% of the time for me), which re-introduces increases input lag.
I think if you want optimal input lag you need to keep it below the max range of the monitor by 3fps, so in this case 57fps or for 1440p, 117fps. That’s what I understand from reading the guides out there. I may have that wrong but that is how I understood it.
Kind of? 4K 120hz and 100hz appears in the NVCpl out of the box in 04.70.05 (engineering version, not sure about public), but trying them results in a corrupted image. So they're trying to implement it, but it doesn't seem to be working yet. I use this cable, so I doubt the problem is on my end.
Did you try 4k/120 it with 4:2:2 8 bit?
Yeah, I tried 4:2:0 8 bit as well, image is still corrupted.
Well it is at least a positive sign that it is now an option. Is 4k 4:2:2 100hz a possibility with 10 bit HDR? Or is that too much bandwidth
Premium Member
That's 32.08Gbps.
Also 32.08Gbps.
When using 4:2:2 all three bit depths (8, 10 and 12) use the same bandwidth. 100Hz and 120Hz both use the same bandwidth as well.
That's 32.08Gbps.
Also 32.08Gbps.
So how are Samsung TVs managing 4k 120?
Do anyone know if Korean firmwares work on European sets? someone must have tested this since we have had several generations of oled TVs by now.
Korean does not.
Even if you try the tv will not let it install. The tv does a check to see if it is compatible
TV - LG C9, C8 & C6 - AVR - Pioneer SC-LX502, Xbox One X, PS4 Pro & Switch
