I know we already confirmed it but 😎
If any of you want to give me an add on xbox it's "TheMrMike95."
Are you sure about that? Because the way my xbox shows it I think it does.So VRR only works on [email protected] [email protected] it is not active. Bit of a let down!
Not to sound like a moron. But if I'm playing a game capped out at 60, but have 120hz set will VRR kick on then? Or will the tv reject it no matter what?Positive. Follow the guide below.
When you get to the last screen you will see the current refresh rate of the TV on the top left. During a game this will fluctuate if VRR is active.
If I try 1440p @ 120 or 4k @ 60 I can see it adjusting for VRR.
At 4K 120 the TV is displaying only at 120 with no fluctuation. VRR not active.
Something over on LG support website stating our model has limited VRR. The max vrr at 4k is 60. I'll dig it out in the morning. It's late here!
On my Xbox everything is ticked etc also. Just not actually working.
How to access the HDMI diagnostics menu
- Open the settings of the TV by pressing on the gear icon on the remote
- Highlight or move the pointer over the All Settings option and open all settings
- Select the Channels option
- Move the pointer or highlight Channel Tuning
- Press the 1 key on the remote five times quickly
- Push right and highlight HDMI and press select to access detailed diag
I'm pretty sure it won't. You would have to change it back in Xbox. Otherwise it just double the frames, will still make for a smooth experience and bring input lag down but may still have some screen tearing present.Not to sound like a moron. But if I'm playing a game capped out at 60, but have 120hz set will VRR kick on then? Or will the tv reject it no matter what?
I'll take a look again, but I swear it's on haha. I'm getting none of the horrendous framerate drop and stuttering in Assassin's Creed Valhalla gets when you turn VRR on. Unless of the game can tell it's capped at 60 and it kicks on then.Positive. Follow the guide below.
It actually says on the rtings page you linked that 4k VRR Maximum is 60.I'll take a look again, but I swear it's on haha. I'm getting none of the horrendous framerate drop and stuttering in Assassin's Creed Valhalla gets when you turn VRR on. Unless of the game can tell it's capped at 60 and it kicks on then.
Edit: Not saying you're wrong, but RTINGS also shows that they get VRR working at 120hz. So I'm fairly confused. (To be fair, it might just not support 4k 120 vrr) LG SM9000 Review (55SM9000PUA, 65SM9000PUA, 75SM9070PUA, 86SM9070PUA)
Nah you're definitely right. Guess I'm not as sensitive to frame drops? Or maybe having the tv set to 120hz just makes things smooth enough for me. Sorry dude!
Yeah I noticed that, but later in the article they said they had nothing to test HDMI 2.1 products on so I assumed it just would haha. Sorry for making it seem I didn't believe you there.It actually says on the rtings page you linked that 4k VRR Maximum is 60.
It could possibly kick in itself under 60. I'm not sure about that. I must check it.
Very nice ! I didn't get a Series X yet but, seeing this, I guess I won't hang tight for a 2tb model.View attachment 3055936
I'm probably going to stick with 4k 120, but depending on the game I may drop back down. Any of the current games all stay very close to the expected frame rate so you shouldn't notice much tearing. Down the line when they are really pushing the console and there are some major frame dips then 4k 60 with vrr might be the better option. Or even 1440p 120 vrr (which I think has the best input lag, though I'm open to correction!)Now that I'm off work today (woohoo!), gonna figure out if I prefer the fluidness of having 120hz on or prefer having VRR on at 60hz. What I wonder is, with autolow latency and game mode on, will I be able to tell much of a difference if the game I'm playing isn't at 120 fps? Because I know 120hz does mean more fluidity/less input lag.
If you scroll up a bit you'll find an in-depth answer. I believe the answer to your question is yes but definitely take a look.Hey guys. Can any PS5/Xb1x/ RTX 30 owner confirm whether the SM9000/9500 is able to do 4k120hz hdr, or sdr only?
Thanks everyone who was able to test the tv and post the results!
By any chance does someone have 49 inch model? Is it really the same as 55/65 in terms of 2.1 support?
And the second question is - I got that the tv supports 4k 120 input but can anyone really confirm that 120 hz refresh rate is really there? Or is it the case of old "HD Ready" TVs that accepted 1080p input but actually had lower resolution of the panel itself. So it's not some stealth 60 hz tv panel that accepts 120 hz signal?
Thanks again for any reply
