1081 - 1100 of 2082 Posts
There is minor crosshatching and the H9F has big time Sub pixel dithering and they gave that a 10. So please stop having a man crush on rtings. They are not the gospel. Sorry. They get things wrong. And how do I know that H9F has cross hatching cause my buddy has one.
That's a shame, I really hate sub-pixel dimming. Do you have any photos, or know if anyone else does?
Go to Advanced Picture Settings and adjust Action Smoothing
I kind of disagree with this YouTuber. I have been switching back and forth between Action Smoothing/Natural Cinema, and I prefer to keep NC on and AS off for most content. He prefers to keep AS on Medium and NC off. But since you have to turn off AS to enable NC, it really is an A/B choice that is easily tested. Try them both and see which one you prefer.
Kind of wish both could be on at the same time.
My 2015 Vizio could do anti-judder and motion smoothing at the same time. I mostly hate the SOE, but sometimes, for some content, the setting helps on its lowest level.
They can't be on at the same time, motion smoothing interpolates the in between frames, there is no room or need left for de judder
Said that way...makes total sense. Kinda now makes me scratch my head what the heck was going on with the Vizio then lol
The 625 really crushes blacks to oblivion if you set local contrast to high. If you try to watch the king on Netflix half the thing looks pure black /forum/images/smilies/biggrin.gif
I just got mine but I think I will return and keep my m558 instead.the 625 is sharper as it doesn't do panel wide subpixel dimming. I swear I saw it cross hatch in hdr light grey but I can not reproduce it at the moment.
There is quite a bit of banding if you pull up a linearization test but I didn't see it stand out during normal watching.
It obviously can get much brighter than the Vizio, while the Vizio maintains visibly better black levels without crushing detail. I don't like Roku that much but Smartcast is the worst. You win some, you lose some.
Oh and I pulled up a 4k resolution chart and it showed aliasing at 20 sharpening and none at 0. A 2 px square test also shows shifting at any value above 0. Im not certain that 20 is no sharpening.
Dse is not the worst but edges are noticeably yellower and darker for me (my partner pointed it out as well) and there is a narrower band at the top and bottom.
*edit. Built in Amazon prime app with Dolby Vision has image processing on that you cannot turn off, it's pretty aggressive sharpening / contrast enhancement. It's a bit strange, I wonder if it's upscaling from 1080p instead of streaming 4k
9.1.2 6463-88 55r625 Default parameters apart from 0 sharpening, Dolby dark, natural cinema, local contrast medium, brightness normal.
The built in roku apps of Netflix and Amazon Prime (only tested with Dolby Vision shows) apply image processing that makes the image appear sharper / more detailed. It looks like selective edge enhancement and it cannot be turned off. Tested at the max bit rate, double checked with the debug overlay.
Furthermore, testing with a 4k resolution chart for aliasing, sharpening seems to be applied at 20 unlike their claim that 20 is the zero point *edit, I changed something else and now 20 seems to be a 0, I really hope TCL can step in and explain what happens between 0 and 20. Also, If you pull the test patterns show in Netflix and use their regular chart, it shows some sort of artifact where the middle 1px bar is drawn through the center photograph. I don't know if that is a gamma or chrome sharpening diagnostic, but it is not visible on the Vizio. The bar also has a color cast on the r625. Unlike above enhancement, this is with the built in app and the fire stick 4k both, tested to be streaming at the max nitrate.
I have none of this. You probably have a bad panel. I have no banding either. Also the Vizio is horrible upscaling and it doesn't get bright the M558. Send it back for another panel. Do you like the upscaling on the Vizio? Star Wars looks beautiful in 4k Dolby Atmos. No black crush at all. I can see all the stars in the sky that is properly displayed. Now we just need the discs.
Also do you have the 55'" or the 65"? I here the 65" may have these problems. I have the 55" and I was looking to upgrade to the 65". I don't know yet.
Pre J1008 firmware the H9F had lousy gradients. I notice skin issues and foreheads were splotchy. With J1008 they really improved gradients and foreheads look great to me now.
Exactly why I won't get the H9F. The TCL R617 had this and that's why the R625 is better.
You can't go by just 1 source or 1 video The king on Netflix. Try Star Wars on Disney +. If you have it.
What mode/settings are you using, and what is your source device? I have the 55.
You can get the linearization test here
https://www.avsforum.com/forum/139-display-calibration/2943380-hdr10-test-patterns-set.html
For Dolby Vision
Tv Brightness- Brighter
Picture Mode- DV Dark
Picture Size-Auto
Local Contrast- High
blacklight-100
brightness-50
Contrast-100
Sharpness- (TCL said 20 is there 0 but I still kinda not buy it. So I go back and forth from 0-20 and in-between.)
Tint-0
Color Temp- Warm or Normal. Sometimes I think the Warm setting feels like Warm #2 on the Samsung and other TV's. Sometimes it's to warm, so I go with normal.
Natural Cinema- On
Everything else off.
Gamma- 2.0 not 2.2 for Dolby Vision.
Oh I am using the Apple 4k TV not the Roku internal apps. I might get the test and check it out.
It's weird though I have never gotten a bad panel from TCL. I guess I have been lucky. I am sure there are bad panels out there and I don't dismiss what people are saying. Not at all. There are bad panels with every tv. But I will say I never got a bad panel with them. Sometimes though the handshake of my old Pioneer Elite which was top of the line back in 2010 gives mean some auto sync problems and I have to go into the CEC and unsync then sync again to get it back the syncing problems. It happened a few times. However that's about it. I am reluctant to go a step up to the 65" cause I hear the 65" is having alot of these problems that people are discussing..
Try doing a hard reset of just the picture and audio on the tv. That may fix your problem.
For Dolby Vision
Picture Size-Auto
blacklight-100
brightness-50
Contrast-100
Tint-0
Natural Cinema- On
Setting to brightest and Gamma 2.0 would lift the black out so that they are not fully crushed, at 2.2 and normal brightness it is too dark in darker scenes. High local contrast also creates a vignetting effect with letterboxed movies that you can see by switching between high and off.
Though mine remains too agressive at local contrast high even with 2.0, with fire stick anyhow, I don't have an apple tv to test with.
I think the motion issue that people are complaining about is some sort of image/noise processing(even with it off from expert settings). If you pull the dark crystal in dolby vision and watch 6:00 to 7:00 in the first episode up close to the tv, you can see that it has this strange posterization effect in between frames, especially around where the spider is escaping. This is not part of the show as I tested on a couple more displays. It remains on with natural cinema on or off.
The other issue, which might be related, can be seen below in the netflix 'test patterns' show where the 1px patterns are carried through the middle, which points to some sort of processing (link) You might have to look at it at 100%
For Dolby Vision
Picture Size-Auto
blacklight-100
brightness-50
Contrast-100
Tint-0
Natural Cinema- On
I used CNET settings and they work great for me. For SDR. I set contrast to 90 not 100.
I see what they did, dropped gmama and contrast both to fit the eotf curve. It specifies this for SDR though, doesn't give hdr settings. I'll put a colorimeter on it today and see what is up. There is also no reason why the 65r625 settings should apply since it's a different panel.
