Hi! Im a PC gamer user and i had several pc monitor and Samsung TV. i play in 4K and love High brightness TV and i have a high bright room.
I have a specific question. i tested several samsung qmed tv in the past, i read several review on rtings and just read reviews at flatpanelhd..
They said the LG CX has a peak brightness of 212 nits in Game Mode in SDR mode, just click the right section for max brightness in nits with each tv modes. For C9 its 205 nits.
To me 212 nits maximum brightness is completely unacceptable in gane mode in SDR Mode. Is it a way with the LG game mode settings to at least increase the brightness nits in game mode to at least 300 nits, i would prefer 350 nits.
My 2 samsung qled tv have at least 400 nits in game mode in SDR. and it just correct for me. Even at 350 nits its a little too dark to me.
Thanks for answer. i dont want to buy a LG Oled TV and have to return it because of the brightness in SDR game mode. i need at least 300 nits in game mode.
Thanks for help and answers its really appreciated. ( im sorry my english is not perfect.
You can get higher, but at the possible risks I'm unsure if its a valid method of pursuing, I've asked a few times but haven't gotten a response back here as of yet. I'm coming from a line of QLED's myself but this year wanted to give both a shot.
I'm the type that likes bright poppy colors and rich darks in games vs the washed out "natural way it was meant to look" that some swear by, granted that's up to the game designer how they want the game to look, and user pref after on best way to bring that out, so regardless if someone tells you its inaccurate, that's their personal preference..and you're rarely going to see a dev or game company that states "this is how you're intended to play it" unless maybe that company is apple or something, whatever looks best to you is what you should go for, not what someone tells you is "correct" or "is the standard for" that's the beauty of diversity, some people can't stand color, others love it, diff worlds diff interests, diff play/view styles, a lot of games are created in the concept that most will have a standard gamut monitor within 72% or so, having a display that can display higher is just a bonus and gives you an overall richer experience, so by all means enjoy whichever that pleases you.
The Peak brightness definitely can hit higher than what you're showing, but only if you set OLED and Contrast to 100, I've particularly found in the Vivid setting ( after reducing color from 75 to 60 ) setting contrast + OLED to 100 I can get near brightness for most areas in games compared to my Q90T, granted the q90t is definitely brighter, the difference isn't as apparent, and acceptable as a normal monitor and def brighter than my other monitors ( QNIX 27" and Samsung 32" monitors ) the scenes are rich and beautiful, HOWEVER given that you apparently need to be in gaming mode which has a static setting for gamut type, it will appear a bit more washed out, almost as if you were in HDR mode in windows where it washes out the colors on your desktop.
This can be alleviated a bit to get within 20-25% of the way vivid looks by boosting color, contrast, oled, and some white point balancing, but won't get as rich ( if that's your thing ) so for me (and I say this personally ) that was 1 con,
The next was the concern of keeping it at max brightness would lower the lifetime on the cells, (or w/e they're called) I did fall in love w/ how rich and well it took care of colors, scenes and overall areas.
I had the q90t and LG CX ( both 65" ) hooked up and mirrored (via OBS full render fullscreen to mirror 1 display ) on the other, that way both calibrations affected the proper TV's, Color wise I got the LG within a few % of the QLED which at that point you're only going to notice it if you really look at them side by side, turn one off and you wouldn't know any better.
Lighting, now the QLED can get brighter in some aspects, depending on the games, and I play a LOT of SDR ones since they're mostly MMO's ( PSO2, FFXIV, AK) + Online stuff like PUBG, Fortnite(friends dragging me in to play) and others, there is a sort of contrast diff in some areas that I notice the Samsung hits better on, but the OLED makes up for it in darks for others, so at that point it comes down to whether you're more into the rich darks, or like the overall pop to your image when it counts for areas where you can really illuminate things, without losing the colors either.
At that point if LG did not have the concern of burn in ( since my games all have static UI's and no transparency option ( for some ) I'd have packed the q90t back up, but given the concerns for burn in at high brightness ( granted it has safety measures in place such as dimming when no movement/action is detected + the lack of information since the panel is new and only older information from users with older TV's on reddit, its not worth the risk currently imo.
Overall its a gorgeous TV, and will probably end up rebuying it later this year when it goes on sale as an additional monitor for work/netflix.
If your store allows for returns, its worth taking a look at, and will definitely give you an idea on the diff between both types, which I feel makes the decision a bit easier(or harder depending ) as well as less regret once you return one.
Thanks so much for answer. i just checked again it was 221nits not 212 nits.. Anyway, i hesitate to change for oled because of gsync compatible and less motion blur. But do you think 300-350nits is possible in Game mode (or PC mode) with general content ??
To be honest i would prefer 350 nits by experience..
thanks for answer.
If it was not for gsync compatible and pixel response time , i think i would not buy a oled. i tried the Asus PQ438q and hate it because it has a LOT of motion blur.
My samsung 55" JS8500 has a very fast response time, no motion blur or smearing, high brightness, but no gsync compatible
I have a samsung ku6300 43" but no gsync and a lot of motion blur.
You see i want a tv/monitor with gsync compatible, good brightness , and low motion blur.
The Samsung Q90T is also Gsync Comptaible, and shows up just fine, the only current issue they have with it at this time is the overdrive is visible in certain games / scene types due to the heavy sharpening, this was apparent in previous gens which was fixed via firmware, so can only hope they fix it again this time, for now I just play in game mode which is under 10ms + game motion+ w/ settings at 0 to prevent the additional processing, and get a clear crystal game play w/o tearing, since I can only max out at 60fps atm anyways till hdmi2.1 hits ( so long as the 3000 series adds a port, or the Display port converter to hdmi 2.1 releases next month ( or this ). So keep that part in mind.
But... if you still want an OLED, here is how you can solve the 220+ peak brightness in SDR for games limitation. Enable HDR in Windows 10. In the current Windows 10 update, they have finally allowed SDR content to look vivid as opposed to looking washed out though colours may look a little off. But with this, your SDR games will be a LOT brighter especially when you enable Dynamic Tone Mapping in HDR Game Mode which spreads the colour and brightness volume from 200 to 700 nits and make full use of the TV's contrast instead of following the game's default tone mapping. Enjoy the 700 nits of peak brightness on an SDR game with this.
Take note, in SDR, the C9 and CX has a Peak Brightness setting, which adjusts how the ABL performs. Setting this to 'Off' results in most scenes being displayed at around 303 cd/m² for the C9 while in SDR too.
Still shows washed out, tested it on both, VERY washed out, and as you stated, this was meant only for HDR style games so you gotta swap back and forth if you're doing SDR.
The LG oleds are the only gsync tvs as of now. I used to own a Samsung qled(55q8fn) and my LG 55cx utterly destroys it when it comes to gaming.
Granted I don't play in a bright room but the cx seems plenty bright for me while maintaining blacks. The qled blacks couldn't compete.
Sent from my SM-G970U using Tapatalk
The Samsungs are as Gsync comptaible as well, w/ the only downside of the ovverdrive atm, as for the blacks, you can definitely notice it in some areas, such as wallpapers, or scenes, but when u look away for a bit and back it just falls in with picture, at that point ( on the new line, I didn't test the 2019 one ) Works great otherwise when on.
But the FALD is pretty good on it at least since I can can adjust black levels/brightness far more and maintain that rich line unlike I could before w/ the 2018, but to your comment since you you don't play in a bright room, I'd def suggest the OLED as well, I'm not sure how they deal w/ reflections at that level either since I kept the lights off in my room since it was bright enough for the qled but could def see it on the TV ( still had the film on though )
Ya, OLED is not a bright room display. It's a controlled lighting/dark room display.
How are you doing that? When I set Windows 10 to HDR and play a SDR game, the OLED gets kicked out of HDR mode. I haven't found a way to force Windows 10 HDR on no matter what (SDR games).
It will only work if the game has the HDR option mode, the application has to support it ( DX features)
