Hi All, Having read all 1170 posts in this thread, and all the posts in the users thread I have a couple of questions on Calibration that hopefully can be easily answered by you knowledgeable folk! I appreciate that as things evolve, some of the information I have taken in may be outdated.
I have a 77CX and a i1Display Pro Plus (new). I am looking to calibrate the display myself using Calman Home LG. I will probably start off with Autocal to 'dip my toe'.
Questions:
1. Should I be using Raw xyz for the meter? I have seen other dll's being used/transplanted from an SDK, but I think this may have been superseded since and is no longer required on the latest version of software? I will use the meter 'as-is' from the box and have no means of profiling it.
2. There was a recommendation to NOT reset DDC and upload the Calman 1D Lut. If I have no intention of using the service menu to adjust white balance, should I just follow the Calman instructions 'as-is' and reset and upload the 1d Lut as part of the workflow or is there actual benefit in not doing so - if so, is it just a case of skipping that step?
3. There was a time that when doing Autocal it was advised to use the LG 2019 setting (I think possibly just for HDR/DV) as using the 2020 selection had issues - I think this is resolved in the latest release of software, and I should use the 2020 setting?
I would welcome any other tips, or specific deviations or extra steps that should be taken from the instructions given on the portrait site here:
Calman Home for LG Walkthrough (portrait.com).
If I can avoid going in the service menu at this stage, I would like to, until I have a few calibrations under my belt!
Thanks, and be gentle
