The set is not calibrated to D65 at the factory. It is calibrated to fall within LG's specs which are more weighted to blue due to the bluish cast of the white pixels. IIRC, I've seen 7000K to 7500K mentioned.
Are you using the internal test pattern generator?HI. Sorry if these issues have been gone over already but i REALLY need som help.
Recently i got all the calibration hardware and software. X rite i1Display Pro Plus and Calman Home For LG. I decided to do manual and autocal for SDR and it has gone smoothly on that front. However i have had massive issues with HDR. When performing Autocal on HDR. The test pattern images are washed out and the screen can not produce blacks through the pattern generator. The DE ERRORS are off the charts and the display only meassured peak 400nits. Am i doing something wrong here? I followed the tutorials step by step and SDR modes worked fine. Greatly appreciated if someone can help out with HDR.
Is this what you are seeing?My 12 Yr old son spotted something I hadn't noticed before and now, of course, it's all I can see. In black areas of the screen we see lighter blotches appear and go with no obvious pattern. These are more noticeable when watching 2.39:1 content in the black bars. A bar can briefly appear lighter and then go back to full black with moving blotches of lighter areas. Is this part of the raised blacks issue or is it something else? My son noticed it when watching a lower quality file so I just assumed it was due to compression but I can now see it in all forms of content. SDR, Hdr10 and DV. Streaming or from disc. This was only noticed once upgrading to the latest firmware so not sure if that's to blame. It was spotted before and now after calibration.
I thought I was picking up on something like this initially, in the bottom letterbox bar. Eventually I realised it's probably a very slight reflection from the TV stand back on to the bottom of the screen. Barely perceptible though.My 12 Yr old son spotted something I hadn't noticed before and now, of course, it's all I can see. In black areas of the screen we see lighter blotches appear and go with no obvious pattern. These are more noticeable when watching 2.39:1 content in the black bars. A bar can briefly appear lighter and then go back to full black with moving blotches of lighter areas. Is this part of the raised blacks issue or is it something else? My son noticed it when watching a lower quality file so I just assumed it was due to compression but I can now see it in all forms of content. SDR, Hdr10 and DV. Streaming or from disc. This was only noticed once upgrading to the latest firmware so not sure if that's to blame. It was spotted before and now after calibration.
So I measured everything with the default and used the internal pattern generator with the HDRvideo from Portrait playing off of the USB. When the autocal greyscale was happening it immediately elevated the black level making the entire picture seem washed out during the rest of the process. HDR produces blacks normally on regular content but trying to do Autocal messed it up and I had to reset the picture mode.Are you using the internal test pattern generator?
Screenshots?
Settings used?
Sent from my Pixel 5 using Tapatalk
No, Off for SDR, ON for HDR and DV.Is it necessary to keep peak brightness setting off on LG OLEDS for calibration?
Thanks for the reply. So will leaving it on cause problem while calibrating in SDR? If not then for what specific reason do we leave it off? Also do you leave it at low mid or high for HDR and DV?No, Off for SDR, ON for HDR and DV.
A couple posts back...Thanks for the reply. So will leaving it on cause problem while calibrating in SDR? If not then for what specific reason do we leave it off? Also do you leave it at low mid or high for HDR and DV?
That should always be set to the default of High for HDR and DV and Off for SDR. If you calibrate with it set one way then change it after calibration, yes you mess up the calibration.
1. Great, okay I got the point regarding the 3DLUT. But for me its still a bit unclear why HDR and DV gets not crushed if I adjust the whitebalance with a target of 250nits. As whitebalance changes in the service menu will affect HDR and DV picture mode, the picture should look different with these modes when I calibrate it for either 123nits oder 250nits SDR, aren't they? Probably, I am missing something.![]()
Sorry if this is beating a dead horse (since I assume it probably is), but I'd like to come back to this response / question regarding SM WB calibration.1. I'm not sure what you are getting at here. SDR/HDR/DV calibrations are not the same. The service menu white balance adjustment does not negatively effect HDR/DV. Also 1DLUT completely bypasses service menu white balance controls.
If I read that correctly, since HDR/DV is always at OLED light 100 and contrast 100, a separate adjustment to one mode (e.g. warm) should be made with backlight 100 displaying a 100% white patch (Ted explains why this is here: LG OLED's 3D LUT Profiling using LightSpace Thread) and another one (e.g. cool) should be balanced with 109% peak white and a lower backlight (for example one that targets 100 nits at 100%).SM Cool for pre-calibrating the 109% White for SDR (with SDR pattern) and select Cool in the regular TV menu.
SM Warm for pre-calibrating for 100% White (with HDR pattern) and select Warm 2 on the regular TV menu.
I have found what may be the same issue while playing Vertigo on a 4k UHD disc. The final scene is very dark and I'm finding these lighter blocks dancing around the blacks. This is HDR10.Is this what you are seeing?
I'm still waiting for the LG service to call me for an appointment.
You're not talking about that red dot right?I have found what may be the same issue while playing Vertigo on a 4k UHD disc. The final scene is very dark and I'm finding these lighter blocks dancing around the blacks. This is HDR10.
I'm hoping you can see it in the image below from the video I have captured as the still's compression doesn't make it look as noticeable as it is. I'm also seeing this in dark bands across the whole image which unfortunately I haven't been able to capture.
I'm wondering if this specific issue may have something to do with my recent calibration where I used Calman's Shadow Detail control. I wonder if I have pushed it too far.
Ha, no that's my video camera. All the lighter blocks on his coat.You're not talking about that red dot right?
