I think Ted explained why mine took so long. I guess it will have to do for nowIt absolutely should not take 6 hours to perform a 4913 point display profile (plus 1000 point pre-roll) in ColourSpace.
Not even with a 1000 point verification included should it take anywhere near that long.
Measuring the total of just under 7000 points, using an i1 Display Pro should take less than 4 hours, and that’s including pre-calibration checks, meter profiling, generating and uploading the LUT, volumetric verification, etc.
And even if I does take 6 hours on average (which it most certainly doesn’t if done correctly), then you can’t compare the time it takes to perform that kind of measurement profile to another that does a simple 21 point automatic greyscale calibration, and 101 points for colour correction. Two completely different types of calibration![]()
One other thing (I've also e-mailed Ted about this, but I think it would be relevant to all). I see these Youtubers claiming that the LG OLEDs can be perfectly calibrated through the WB Service menu only, resulting in amazing dE.
