701 - 720 of 1325 Posts
Called Amazon today and they're going to send me another TV on the 9th so I can see if it's any better. Hopefully I do better in the panel lottery this time!
I gotta say, Amazon's customer service has improved substantially in the last year.
Question for you guys, I've been having an issue with voice sync using HDMI as sound thru my Onkyo receiver. The issue is that when watching cable the voice sync will be nearly perfect and as I'm watching the show after a while it will slowly get worse and worse syncing up. I messed with the av sync settings on the receiver and on the tv setting av sync to on. It's just weird that it only happens on HDMI and not optical. I use the HDMI as a central hub for audio and still use HDMI ports on tv. It's very a annoying and cannot figure this out.
Easier way....
Download the CalMAN Bravia app from the Google Play Store, and connect to the TV over LAN/WiFi from an internet browser. To do this, open your web browser and put in the TVs IP address and the correct port number (i.e. 192.168.1.100:9022). Once connected, you should be able to select the two new modes.
I'm having trouble, I type in the IP address and port number, tv says connected, but It doesn't unlock the two pro modes.
Am I missing something?
Got a quick question for the audio peeps out there: I have a 2.0 Vizio soundbar that's kinda sorta old and doesn't have HDMI. I had it connected to my old TV with an optical cord because it's the next best thing to HDMI.
The 950G I used to have and the 950H won't output any sound if I connect the soundbar optically. Is there a sound setting I'm missing to change or something or is it simply not compatible?
I ask because I have the soundbar connected via bluetooth and at first it was fine, but now it cuts out for a second every so often.
I was having sync issues with ARC over HDMI until I turned off Passthrough on the TV's audio settings and set the output to Auto 1. None of the other setting options seemed to make a difference. The sync issues were happening for both over-the-air and media player sources. This means I can't get DTS passthrough now, but I can live with that if it means no audio dropouts or sync issues.
Best of luck.
There must I ask because I have the soundbar connected via bluetooth and at first it was fine, but now it cuts out for a second every so often.
I don't have this TV, but there must be audio settings that let you control whether audio comes from the TV speakers, the optical output, or both**. There is also probably a setting for you to change the format for the audio, and depending on the TV and the soundbar, you may need to set it to output in PCM format.
** As a tangent, I really hope the 950H at least has an option allows you to keep the TV speakers active when a device is connected via optical or the headphone jack. It's really annoying to me that many TVs don't allow this anymore. On my older TVs, the optical output was always active no matter whether you had the TV speakers on or off, and that's what I would like to see from all TVs.
Hey guys,
New to the forum. Just moved to a new house so I bought a couple of new TV's - 55" LG B9 in main room and 85" Sony X950H in rec room. I am coming from a ST60 Plasma, and once I set up the X950H I noticed what would be called clouding in the 4 corners and I was hoping you guys could tell me if I have a bad screen or if its completely normal.
I understand that it is mostly only noticeable on a HDR feed, in a dark room and in dark scenes. I guess the first show I watched was exactly that so I noticed it a little bit during some scenes.
I am a bit of a picky person but if you tell me its normal I am sure I won't notice it in time.
(Note the picture makes it more pronounced obviously).
Hey guys,
The picture you show appears to be from a Netflix menu page, unfortunately Sony turns off Local Dimming on menu screens (No one know why). One of the functions of LD is to compensate for clouding, when LD is on you should not see clouding like this.
TL:DR Clouding like that is normal on menu type pages.
  • Like
Reactions: galonzo
Hey guys,
Make a picture of black picture with local dimming on high, but NOT on menu or loading screens.
Sent from my SM-N975F using Tapatalk
Hey guys,
Since your TV is wall mounted, is it angled down some? I know that when I had my X950G the clouding in the corners were worse when the TV was angled down due to I am guessing the pressure put on it. If I angled the TV back up to level, the clouding was better. I returned that TV for other reasons but my X950H doesn't have that type of clouding in the corners but I also have mine on a stand now.
I also wonder if this is the reason the TV is angled back some on the X950H stand.
Hey Guys I just got a new x950H today 55in and love it. I wanted to know if those settings on the first page are settings you would input on the TV? or are these calibrator settings using calman bravia?
Wha-wha-what? On a wall mount, when angles down, there is increased pressure on the corners of the tv? I hope not because I've got mine angled down quite a bit to deal with reflections...
Sent from my LM-G820 using Tapatalk
To follow up on my previous post. Looks like X-Motion-Clarity on the X950H works different than on the X950G.
X950G has X-Motion-Clarity activated at Clearness 1 and any Smoothness
X950H needs at least Smoothness 2 and Clearness 2
Confirmed by HDTVTest in his review of the X950H
Confirmed by rtings after latest update
Update 07/06/2020: We previously mentioned to activate the BFI feature, the 'Clearness' slider can be set either at '1' or '2', according to your preference. However, 'Clearness' and 'Smoothness' sliders must be set at '2' for it to work. The text and the settings page have been updated.
WTF Sony ?
WTF Sony ?
WTF Rtings? ;)
Bad news on the X950H while testing Dolby Vision...Dolby Vision is basically broken as far as I can tell on this current firmware. I noticed previously that when I switched from Dolby Viksion bright, or as I call it TOO BRIGHT mode, to DV dark, my whites all turned green. It was so noticable that I can't use dark mode, and only use bright.
I finally put the meter on the TV and used the Spears and munsil Dolby Vision UHD disc to throw patterns at the thing and read the luminance and color of the bright and dark modes. Well, bright was no suprise, way way too bright...50% reference white in HDR is 94nit, and DV bright mode is like double that...TOO BRIGHT!
Then I tested DV dark, and the green issue was extremely apparent on the readings...like massive green/red shift...more accurately, blue just falls off the map and appears to have been killed by COVID19 or something. I am posting pics of Calman charts for bright and dark, so you can see how dark is BROKEN, VERY BROKEN. The thing that pisses me off the most about this, is that dark is the profile that actually tracks PQ luminance curve properly, or at least almost properly, while bright is double the luminance that HDR calls for. I cannot correct the bright luminance curve...I tried lowering gamma and lowering contrast but the results ended up cutting peak brightness from 880nit to 680nit. I can't alter the 2 point to correct DV dark without destroying all the other picture modes for HDR and SDR, since the new Sony TV's rerquire using the same 2 point gain and bias settings for everything in a specific source. Keep in mind the tests were done with calibrated settings, which are spot on for SDR, and HDR10.
So see below...if anyone else has noticed the green shift, maybe we need to contact Sony for a fix. For now, I am using DV VIVID (set to same settings as DV Bright, but contrast reduced to 80...closest aproximation for now to accurate luminance cuve without the blue drop.)
I bought the 55" 950H a few weeks ago. It's definitely an impressive set.
However, I'm noticing a strong green/yellow tint in the whites, particularly on Expert 1 and 2 color settings. It sounds exactly like what you describe above or what can be seen in Vincent's review when showing Dolby Vision Dark. Why am I seeing this in other picture presets? I can't completely pull it out of the gray scale. It's maddening, because I know this TV could have an amazing picture. I'm hesitant to replace my set, because it's a great panel otherwise-- no noticeable dirty screen effect or uneven screen uniformity.
Could this be a bug? If so, could an upcoming firmware patch fix it? Should I consider replacing it?
Discussion Starter #719
Unless you have a meter, your best bet is "perceptual" white balance correction with the RGB Gain controls until your whites and greys appear proper to your eyes. It's an actual thing....perceptual matching...so don't be afraid to give it a shot!
https://www.lightspace.lightillusion.com/perceptual_colour_match.html
Paul
Discussion Starter #720
WTF Sony ?
The interesting thing is...if BFI and X-Motion Clarity REQUIRE sliders to both be set to 2, then what the absolute F do setttings Min and 1 do for those sliders? Seriously makes no sense.
Paul
