Status
Not open for further replies.
1 - 1 of 1 Posts
I am planning to purchase a BPT BP-3.5 from Chris Hoff when they come out in about 4-6 weeks. He recommends placing a 20A voltage regulator prior to the BPT unit in the electric 'path'.
After much searching, the only 20 amp 'audio grade' voltage regulator I have found is the Furman AR-1220 . ExactPower makes the EP15A , but it is only rated at 15 amps. There is also the Monster AVS2000 , a variac based unit, but it is also only rated at 15 amps. Since my receiver is rated at 12A maximum draw, and all of my other gear (except amplifiers) will be connected to the BP 3.5, I definitley want a 20A regulator.
I found numerous industrial type voltage regulators like the ones from Electronic Specialists, Inc , but after speaking with one of their engineers, was talked out of it. He mentioned that they were big, noisy, and not intended whatsoever for HT use.
Anyone have any experience with other brands of voltage regulators or have any recommendations? Thanks!
1 - 1 of 1 Posts
Status
