Status
Not open for further replies.
1 - 5 of 5 Posts
I have been searching the forum for any tv 24-27 inch lcdtv that has a cablecard and atsc tuner. Only one within this size range that does is the new sony xbr(v-series?) that cost much more than anything of a similar size. So are there any other lcdtvs around this size that has these features.
And LG 26LX2D, too.
Robert
27" Panels are Taiwanese from what I can tell. 26" appear to be korean and japanese.
Theres an exception and that is that Toshiba is using 27" panels HOWEVER it looks like they are probably using the Taiwanese panels with better electronic circuitry.
Westinghouse will have a new 27" with HDTV tuner. Unable to confirm if it will have cablecard yet. It will be an 8ms panel using the Chi Mei Optoelectronics panel.
I heard that Samsung AND Sony are now starting to use Taiwanese panels on some models as well (on the smaller panels). This is unconfirmed at this point. Quality of the Taiwanese panels has gotten alot better from what Ive heard.
1 - 5 of 5 Posts
Status
