1 - 8 of 8 Posts
don't know if this is the correct forum for this question, feel free to move it.. Bought a remastered 24 bit Hi-Definition audio cd. At least thats what the bright red sticker said on the cover of cd..Would I hear any difference in the music? Just upgraded my player to a NAD 542 ..thanks in advance
A Redbook CD is 16-bit. So there is no such thing as a 24-bit CD. What it probably means is that it was an original analog recording that was re-mastered at 24-bit and then noise shaped to a 16-bit for the CD.
This is a lot like many DVD's use the "from a 1080 Master ".
Discussion Starter · #3 ·
Will: thanks for clearing that up.. should sound good.. The cd is Vollenweider "White Winds".. When I get some free time
I will listen to it.. Matt
It is an older analog recording transferred/digitized. I remember enjoying it.........................way back when.
Not likely since it is "down-rezed" to 16bit for the CD.
What we really need is a simple stereo audio format that is 192khz/24bit on discs that play like CDs.
Originally Posted by SiriuslyCold /forum/post/14265218
most of these usually benefit from extra careful mastering etc so there may be some improvement
Yeah, but most still participate in the dreaded "loudness" war. An earlier 16bit mastering often sounds better because of this.
1 - 8 of 8 Posts
