1 - 3 of 3 Posts
I am looking to get into the semi DIY build and have interest in the Rythmik DS 1500 kit putting it into a pre-built sealed PE box 3.0 cu. My room is 16x20x9.
I would like to stay around the $600 range and want to see if this is my best option or would a different set up work better with the 3.0 cu PE box. I have a Mac so I have not been able to model any scenarios. I appreciate the suggestions with my build. Thanks.
"best" option is tough. you have a good plan there that should make you happy. it is one of many in the "win" category.
an epik legend may be another option.
i could split some hairs, but that would miss the point. good luck with your build!
1 - 3 of 3 Posts
