Originally Posted by leftkidney /forum/post/0
yea it is possible that heating up the board would fix a cold solder joint I have used this technique for years on all types of old servers that have lots of chips on them
if you have no other choice but to pay a lot of money to get it fixed or cant because you opened it try the heat gun or better than that I use a chemistry oven that can be controlled within .2deg. and heat it up to about 175-190C and let sit for about 1 or 2 min at most and take it out
gently press on the chips with a thermal glove on and apply firm pressure the big chips it is possible to fix it this way any hotter than 190C and you risk burning the chips and or setting fire to the silicon
of corse make sure to mount the board inside the oven properly so as not to let it touch anything but the mounting points
Originally Posted by HeadRusch /forum/post/0
If your 360 has red-lighted after monthsa nd months of use this technique wont be of benefit as by then all the thermal compound will have settled and hardened on the chips. However, if it is a cold-soldier issue, then this may fix the problem....albeit in a very, very ghetto fashion![]()
Originally Posted by briankmonkey /forum/post/0
back in the old days we would just blow into our systems or blow the games, lol
